Dyeing the interior
Old Jan 11, 2005 | 02:28 PM
kona's Avatar
kona
Default Dyeing the interior
Okay I know where to get interior Dye and that it is done all the time the question I have is if you go from a lighter color (tan) to black is there any problems with bleeding or rubbing off on your clothes?
This is a Vinyl interior.
Kona
Old Jan 11, 2005 | 04:22 PM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
Kona
no..... if anything it flakes off if surface is cleaned correctly....should not rub off.....
Old Jan 11, 2005 | 06:22 PM
Michel B's Avatar
Michel B
From: Ville de la Baie Quebec. A winner is just a loser who tried again.
No problems with mine...... I'm sure you know this,,, but like all painting and dying,,, make sure thte surface is degreassed completly.
Old Jan 11, 2005 | 06:44 PM
vette_newb's Avatar
vette_newb
I'm in the process of doing mine right now from light blue/grey to black. I have a couple coats down on most of the pieces, and so far no flaking or chipping. Mine's vinyl as well. I'll probably end up going over it all once more just for good measure
Old Jan 11, 2005 | 06:46 PM
crf311's Avatar
crf311
Clean, clean, clean, clean, clean, and then clean again. Then dye and you sould be ok. The more you clean the better it is going to look and stay on.
Old Jan 11, 2005 | 09:10 PM
kona's Avatar
kona
Thanks for everyones help. One more question thou would your first choice be air brushing to apply the dye? Brush? Hand apply?
Thank's Kona
Old Jan 11, 2005 | 09:37 PM
Michel B's Avatar
Michel B
What do you mean by hand ?? like applying with a paint brush ? I sprayed mine,,, the results are quite remarkable, don't know about paint brush methode...
Old Jan 11, 2005 | 10:57 PM
Glassbowtie77's Avatar
Glassbowtie77
Spraying is the way to go, never heard of brushing it on.
Old Jan 12, 2005 | 06:53 AM
BobKatttt's Avatar
BobKatttt
Default Brushed
I did brush mine and it turned out really nice. just be sure to tape off anything you don't want colored. The dye will eat into anything plastic before you can wipe it off.
Old Jan 12, 2005 | 08:21 AM
Xakk's Avatar
Xakk
What about going from a dark color to a lighter one? My t-top panels are a dark blue and I need to dye them camel. Does it take more coats than it normall would otherwise? Any problems losing the grain detail?
To Dyeing the interior
