Stuck Hood Latches- HELP !
Old Jan 11, 2005 | 07:50 PM
Glasspacked's Avatar
Glasspacked
Default Stuck Hood Latches- HELP !
I bought a '73 L48, went to open the hood & pulling the release is not doing it. Is there a way to get to the latches in case the release cable brakes? I would imagine someone must have run into this before. thanks in advance for any help.
Old Jan 11, 2005 | 08:28 PM
Glassbowtie77's Avatar
Glassbowtie77
If your cowl area is the same as on mine there should be two pop-out plastic plugs directly behind the latches that let you stick a thin flatend screwdriver in there and into a slot in the hinge. Twist the screwdriver clockwise and it should pop the latches. Don't know if it's the same on a '73 or not, maybe someone else could help further.
Old Jan 11, 2005 | 08:35 PM
73jst4fun's Avatar
73jst4fun
By the wiper compartment there are two good size holes on the forward wall that allow you to release the latches with a screw driver. If the cable fails to release by jiggling the hood there is another alternative, go to the inner front wheel wheels and look for the bolts that hold down the hood front brackets. The bolts have to be slotted then backed out from the wheel well, on my 73 I had to remove a small fiberglass cover on the passenger side to get to the bolts then reglass it on, not the easiest way but you can get the hood off that way... been there and done that......
Old Jan 11, 2005 | 08:44 PM
robertmc48's Avatar
robertmc48
Veteran: Marine Corps
try this outhttp://www.madvet.com/shop?store=1&c...236&frame=3852
Old Jan 12, 2005 | 09:29 PM
Glasspacked
Default Now THATS an answer!
That link is great! thanks!
Old Jan 17, 2005 | 03:13 PM
Pumpkin's Avatar
Pumpkin
5th Gear
That is a great link and this is a very timely post as my hood didn't open yesterday. Was going to do an quick oil change, and and snap went the cable. Another project
To Stuck Hood Latches- HELP !
