front spring removal
Old Jan 11, 2005 | 08:43 PM
john1977's Avatar
john1977
Default front spring removal
Its been 2 years since i had my front springs out,and because of the front ride height i think they may not be seated properly. I forget just how much has to be removed. Can you remove the shock,and just the lower balljoint and get the spring ou???? I can see the top part of my spring is not centered and is rubbing.
Old Jan 11, 2005 | 08:52 PM
TheKomoman's Avatar
TheKomoman
St Jude Donor '13
Yes, you can. Removing the lower A arm is not necessary.
Old Jan 11, 2005 | 11:15 PM
78Vette-SA's Avatar
78Vette-SA
Wih a spring compressor shoved up the shock hole and honker down on the spring a little, along with a pry bar, you could also pop the spring into place without taking it all apart.
I put the compressor up in there and catch the spring a little off-center (using a square steel plate on the bottom of the a-arm over the shock hole). By grabbing the spring off-center and compressing it and puts a little curve in the spring. Then I take the pry bar and with a little wiggled and get it to pop into place.
Old Jan 12, 2005 | 09:48 PM
john1977's Avatar
john1977
I really would like to take the spring out,repaint,and reseat. Have done this before without a spring compressor but could someone give me a step by step as how to do this again???? Think my memory is going or im just getting older and dont want to get hurt.
To front spring removal
