Power Steering Fluid Hoses - Leak
Old Jan 11, 2005 | 10:03 PM
bulldog90's Avatar
bulldog90
Default Power Steering Fluid Hoses - Leak
I have replaced the power steering fluid hoses on my 69 but they are still leaking - I am afraid of overtightening - anybody have a trick of the trade.
THanks in advance
Old Jan 11, 2005 | 10:38 PM
greyghost79's Avatar
greyghost79
unless the flare is warped it should seal with proper torque. i'd try to tighten more in small increments. never tried it, but teflon tape "might" work.
Old Jan 11, 2005 | 10:53 PM
Glassbowtie77's Avatar
Glassbowtie77
That's what I'd try also. If it doesn't work you probably have a bad flare or you may have cross threaded one on the bolts putting them in. More than likely though you didn't tighten them enough.
To Power Steering Fluid Hoses - Leak
