center console carpet glue??
Old Jan 13, 2005 | 05:56 PM
smoothsailing's Avatar
smoothsailing
Default center console carpet glue??
Installed the new floor carpet. Now doing the center console on the fiberboard. How do you guys install it? Must be glue right(and staple)? What brand glue. The old carpet on my kick plate was stapled. What do you recommend?
Old Jan 14, 2005 | 12:46 AM
c3 in hawaii's Avatar
c3 in hawaii
I used carpet adhesive from home depot to re-do mine, and held up great. also had to re-cut my fiberboard because my pieces were cracked
Old Jan 14, 2005 | 06:03 AM
Pauld's Avatar
Pauld
I made new fibreboard pieces using the old ones for templates and then used contact adhesive to glue the carpet to the fibreboard, no need for staples. This stuff is very strong and you have to be very accurate when attaching to the fibreboard, you have no margin of error nut the finish is superb, once stuck it never comes off. Just take your time and it will be fine.
Old Jan 14, 2005 | 07:36 AM
den(thevetteman)78's Avatar
den(thevetteman)78
I used contact adhesive to glue it and did well. To put in right you can do it just like instaling counter top ,put conctact ciment on bought parts and when it dry just use 1 inche strips of carboard use as many to raise the carpet so it don't touch the panel ,when you have fitted the carpet just removes the stripes one at the time so this way you are sure it will fit perfecly .No staples .
Old Jan 14, 2005 | 07:59 AM
79blue's Avatar
79blue
Only had to use staples on the plastic seat backs.If you use staples be sure to use real narrow ones or you will see them. Home or commercial Carpet installers use them.
Old Jan 14, 2005 | 09:26 AM
mooneyd's Avatar
mooneyd
I used 3M spray adhesive on sides of console and backs of seats.
You must be accurrate placing the carpet because once it is down thats it. Mine came out great
Good luck.
Old Jan 14, 2005 | 08:30 PM
C3 Stroker's Avatar
C3 Stroker
I use the same adhesive that I use for subwoofer speaker carpeting- 3M Super 77 spray adhesive....this stuff works great.
Old Jan 15, 2005 | 04:36 PM
redc3's Avatar
redc3
Good luck.
i use the 3-m spray adhesive on all projects like this. its fantastic stuff. i replaced SHAGGY 70's lookin carpet on the console sides w/ vinyl same color as interior. every vette guy that notices loves it
Old Jan 15, 2005 | 04:43 PM
Motor City Vette's Avatar
Motor City Vette
Good luck.
To center console carpet glue??
