OT - Bondo
Old Jan 13, 2005 | 06:46 PM
AGVI's Avatar
AGVI
Canadian Events Coordinator
Default OT - Bondo
Will it harden on its own eventually without the 'hardener'??
TIA, Les
Old Jan 13, 2005 | 06:56 PM
HDIronman's Avatar
HDIronman
no...
Old Jan 13, 2005 | 08:17 PM
72LS1Vette's Avatar
72LS1Vette
I suppose it might dry out eventually if exposed to air but it's the chemical reaction between the filler and the hardener that makes the putty set up correctly.
Rick B.
I owned an Alfa Romeo - I have a lot of experience with Bondo.
Old Jan 13, 2005 | 08:28 PM
codestar7's Avatar
codestar7
Default Hardener
From practical experience it will haden over about a year in the open to something resembeling a piece of cracked and broken kindergarden clay.
Old Jan 14, 2005 | 05:14 AM
Hidro's Avatar
Hidro
No,
you can buy the hardener seperately if needed.
Old Jan 14, 2005 | 09:55 AM
kens 80's Avatar
kens 80
I'm fairly new to the forum so I apologize if this has been said before. If 1 drop of Hardener was put into a gallon of "bondo" and throughly mixed it would eventually cure. But no hardner, no cure.
I hope you guys know that the C-3s are actually SMC not true fibreglass, and when doing any "bondo" work on the bare body you should be using the SMC "Bondo"( SMC stands for Sheet molded compound). If you are using "bondo" over paint, the regular stuff is OK, but I dont recommend it.
Old Jan 14, 2005 | 10:43 AM
AGVI's Avatar
AGVI
thanks for the replies...it's not for the Vette by the way...
To OT - Bondo
