Header/Sidepipes Install
Old Jan 13, 2005 | 07:46 PM
es's Avatar
es
Default Header/Sidepipes Install
Is it easier from the top or from underneath? I just got the pipes and haven't had time to take a good look. When I take off the regular headers that are there now I'm sure they will have to come out the bottom.
Old Jan 13, 2005 | 07:56 PM
Z-man's Avatar
Z-man
Depends on what you mean by easier.
If they fit from the top, it's easier from the top since you don't have to lay on your back and get crap in your eyes. If they don't fit from the top, the only choice is from the bottom, so that's easier...
Old Jan 13, 2005 | 08:58 PM
jdmick's Avatar
jdmick
If you're putting on the Hooker side exhaust this article might help.
http://www.corvettefever.com/howto/4680/
John
Old Jan 14, 2005 | 04:55 PM
es's Avatar
es
Thanks for the link to the article. It answered more than one question for me.
Old Jan 14, 2005 | 06:53 PM
The Dude's Avatar
The Dude
Sidepipe headers--like the Hookers--WILL NOT go in from the top. Don't waste your time trying. It's not going to happen.
They'll go in from the bottom and it will be handy to have an extra pair of hands up to to start a bolt or two once they're up there. Also, Hooker says to raise the car 36" off the ground. They're not joking, although it can be done on jack stands. Be very, very careful, though.
Old Jan 14, 2005 | 10:19 PM
Red73's Avatar
Red73
I did mine from underneath with the car on jackstands.
Old Jan 14, 2005 | 10:22 PM
LOTAHP's Avatar
LOTAHP
My right side goes in from the top with no problem (no AC). The left side from the bottom.
Old Jan 14, 2005 | 11:10 PM
es's Avatar
es
How do I get the thing 3 feet in the air? I have a Quicklift but the bottom of the car is no farther off the lift ramps than it would be off the ground. I have used jackstands on the lift quite often when the lift is in the raised position to do any "wheels off" type of work but there is still only clearance equal to the height of the jackstands. It just puts the car at a more comfortable working height.
Old Jan 14, 2005 | 11:17 PM
jdmick's Avatar
jdmick
You shouldn't have to go 3 feet in the air. I took my headers and pipes off all in one unit a couple weeks ago. FFvetteman showed me some pics in this thread
http://forums.corvetteforum.com/showthread.php?t=980613
I would have thought you had to go a lot higher than his pics but trust me, it can be done. John.
Old Jan 14, 2005 | 11:24 PM
Red73's Avatar
Red73
Mine wasn't three feet in the air. Yes the car is on the jack stands and not solely supported by the blocks.
Old Jan 14, 2005 | 11:36 PM
es's Avatar
es
It looks like I should be able to set up the stands on the Quicklift and have the whole thing at a good working height. The car will already be on the lift from taking off the old exhaust system.
To Header/Sidepipes Install
