Clutch spring locations.
Old Jan 14, 2005 | 11:24 AM
Brian Hall's Avatar
Brian Hall
Default Clutch spring locations.
A less than honest mechanic has left my C3 in pieces and I could use some help. Where do the pedal return and clutch anti-rattle springs attach ?
Thanks for any help,
b.
Old Jan 14, 2005 | 01:14 PM
PRNDL's Avatar
PRNDL
this pic should help. The return spring AKA the "firewall" screen should have a hook at the firewall. The antirattle springs hook into 2 little holes in the lower clutch rod (that attaches to the clutch fork)
Old Jan 14, 2005 | 02:44 PM
i885744's Avatar
i885744
I have the same question. The "firewall spring" where does it attach? to the bracket on the frame and the clutch rod? That doesn't make any sense. Mine squaks unless i have my foot resting on the pedal.
Old Jan 14, 2005 | 03:03 PM
Fevre's Avatar
Fevre
There is a flat bracket with a small lip that surrounds the clutch rod as it comes out the fire wall, there is a small hole on the underside that the spring goes through.
To Clutch spring locations.
