Electronic fuel pump placement
Old Jan 14, 2005 | 11:29 AM
DVG73's Avatar
DVG73
Default Electronic fuel pump placement
Where did you guys put your electronic fuel pumps? I got one the other day and was trying to figure out the best location for it. I figure it should be close to the fuel tank. Pics would be great. Thanks
Old Jan 14, 2005 | 11:32 AM
GrandSportC3's Avatar
GrandSportC3
Cruise-In IV-V-VI-VII-VIII Veteran
St. Jude Donor '03, '06, '17
I'm planning on installing mine on the bottom of the fuel tank crossmember... I don't have a spare tire carrier..so I should be ok...
Old Jan 14, 2005 | 02:11 PM
DVG73's Avatar
DVG73
I had that in mind as I too am ditching the spare tire, but I was also thinking on the side rail near the tank. I guess I need to play with it to find an appropriate location.
Old Jan 14, 2005 | 02:14 PM
Corey_68's Avatar
Corey_68
That's where I have mine, I'm running a Holley Blue with no problems.
Old Jan 14, 2005 | 02:39 PM
i885744's Avatar
i885744
not on the vette, but i put one on a 78 chevy truck that we did a tpi swap on. Made a bracket and bolted it to the frame rail right next to the tank. As long as the pump is pushing the fuel foreward rather than siphoning you're fine. The closer to the tank, the better.
Old Jan 14, 2005 | 03:31 PM
Sleper's Avatar
Sleper
Removed teh spare tire and outer carrier. Located it right under the tank on the carrier support. Good luck
Old Jan 14, 2005 | 03:52 PM
superdad60's Avatar
superdad60
I have a Holley Red
Still have my tire carrier
I Put the pump on the frame rail between the 2 right taillights
There was a mounting hole there. I drilled a second for the bracket
To Electronic fuel pump placement
