As a trained alignment guy (non-practicing), make sure you find someone who has good equipment, knows how to use it, and will take the time to do it right. If only I could find a shop that would rent me time on their rack to do my own alignment...
you dont know how often ive had that exact thought! ive done alignments, and with todays machines its simple stuff to do! i always wanna run in the shop and do it myself. i love when sales guy gives me his rap and i know more than he does
Red, it definately isn't difficult, but it does take some practice to be comfortable with proper set-up of the equipment. It's been a while for me, and I know that I would need a few minutes to re-familiarize myself with the proper procedures, so that I was sure all measurements were accurate.
The only thing I miss about working for the aligner manufacturer is being able to pull my car into the test garage on my lunch break and align it myself.
Hookup with the local clubs and ask who they recomend. You need a shop that knows Vettes. Network, ask local high performance shops who they use. Good luck.
Sears in my area wouldn't touch the vette, ended going to Good Year
My local sears wouldn't touch the vette. The tech I talked to originally told me to pull the car up. As I was doing that, the manager came out screaming to get that car out of here. They won't do it.
Took it to Goodyear. A young kid said he didn't know how, but if I would show him where the adjustments were, he'd hook up the machine and make adjustments. Charged me half price, and I got to help.
My local Car-X shop here in St. Charles, IL has the best alignment equipment in town, and some pretty good guys that know how to use it. My car drives great after the $100.00 job they did. Everything was new so they didn't have to beat on and heat things to make adjustments. These vettes rust real bad, especially where the trailing arm shims go, so be prepared to spend a little more if things are rusted together. I would suggest replacing all the parts that wear over time and then have it aligned.
Ask around...find someone who knows vettes...in my area I found that the Goodyear store here has an expert Corvette alignment guy who specializes in older vettes. He will even customize to your specs for racing if you wish with no extra price increase.......by all means find someone familiar with your car if you can.
After those guys messed up a wheel stud and then messed up an ABS sensor replacingt he wheel stud, I will never go to Sears again for service. All I did was buy a set of tires for my Grand Prix!
My $$ for alignments goes to a local shop that's been around for a while. They do excellent work, align the car dead-nuts to spec, and they charge accordingly. I think a dead-nuts 4-wheel alignment ran me $130 a couple years ago. Well worth it.
There's probably a shop around you that can do a good job. A C3 is NOT easy to align and it shouldn't be cheap.
I did a search for companies with the word "alignment" in their name using Yahoo Yellow Pages. There are 10 places within 20 miles, and I live in NH. Chances are you will have even more than that near you.
I would trust someone like that before I would let Sears near my car.
the front is childsplay, i can get it pretty close with home techniques to drive to the shop. the rear is only hard part and thats only because of dissasembly. a lot of shops will charge incredible prices for things like shims and not even use them. be carefull
I second the recommendation to call the local vette shop or club for recommendation. For example, Van Steel in Clearwater, FL uses one shop for tire install and alignment; I can trust their recommendation. Also, I got lucky at a Sears Auto Center where a guy that had been aligning cars for over 30 years and well known to the folks at Van Steel happened to just have transferred over to my neck of the woods.
