Smog Laws
Rick B.
Exactly right Tom.Isn't this always the case. Although I haven't done this, my understanding is that you go to a "referee Inspection Station" (not sure if this is the correct name) to have them judge that your mod meets their requirements (not sure what that means). If it does, they will grant a certificate accepting the mod. You'll only have to do this once. Again, I've not done nor known anyone that has gone through this.
I think that your example of a crate motor is the most typical and logical of the mods that would be acceptable, tha rational being that a modern motor will product less emissions. I also understand that if you add a modern motor, you also are supposed to add all of the accompanying emission goodies such as O2 sensors and cats, if you don't have them now.
I spoke to The Engine Factory and they said they could build a motor with smog legal heads and manifold, use a quadrajet (mine is pre computer) and with the stuff switched over it should pass smog - no?
This is really my pet peeve with the law. If the intention was to reduce emissions, then what you're proposing would obviously reduce the emissions, but according to the law this isn't rellevant.
soon to be 383ci vert. road ready calif member.
by the way they said that 76 and up will still be included in the system.
. give the auto repair burea a call to double check. the dmv isnt a source to get info... there not the inspectors...
Great story about state run "smog only " stations.
When I first got the car, I had to take it to smog only station because I bought it from a guy who lived in Sacramento which was under special testing requirements. He didn't want to deal with it so I said sure I'll take care of it. The car was in really nice shape and I trusted the guy when he said it would pass.
So I find the nearest "smog only station" , about 45 minutes over the bridge in Richmond. The guy, who seems really knowledgable, tested the car. It passed but the timing was off a degree or two. No problem right- adjust it and I'm set. Except the smog only stations are just that - no adjustments or repairs. Pay for the smog test and go. What, huh?
So I drive the hour home, adjust the timing and take it to a local guy and pay him to put it on the dyno smog machine (which is not even required for such an old car) just to make sure it passes before I drive back over to Richmond from S.F. It passes no problem and I now pay him in addition to the paying the smog only guy. Back to Richmond the following week (you have to make an appointment and they are hard to get.) I pay the smog only guy one MORE time and guess what-- it passes, just the way it did the first time when the timing was a little off and the second time when I wanted to make sure it would. I paid for THREE smog tests, and spent 2+ mornings waiting around and driving back and forth.
Anyone want to move to California?
