Accessory drive
Old Jan 15, 2005 | 07:43 AM
Guru_4_hire's Avatar
Guru_4_hire
Cruise-In IV Veteran
Cruise-In V Veteran
Default Accessory drive
What is the prescribed accessory drive system for prolonged high RPM situations?
Old Jan 15, 2005 | 07:53 AM
Twin_Turbo's Avatar
Twin_Turbo
cog belt drives or use 2 V groove belts w/ deep groove pulleys on all accessories.....as far as I know. I have deep groove pulleys and 2 belts on the water pump, in case one fails. For power steering I have just 1 belt, same for alternator.
I've always liked the cog belt setup of those race mate alternator/waterpump combos, too bad they're so damn expensive and not high amperage. If you don't have a lot of accessories and only lights & engine to run (no radio, power windows & such) the racemate may be a very good choice.
mrvette's Avatar
mrvette
I think it's a serpentine system....
olde tyme V belts had to have deep pulleys to keep from tossing about 6 grand at the drags, for instance, I think NASCAR may still use them, about the only ones that do, if any...
GENE
Old Jan 15, 2005 | 08:01 AM
Guru_4_hire
Cruise-In V Veteran
Hmmm
I am gonna have a power steering pump, alternator, water pump.
As far as things drawing power. Radio, 3 electric pumps, and an electric fan, various dash lights, and a heater fan. Maybe a fan on an oil cooler.
Old Jan 15, 2005 | 08:02 AM
Guru_4_hire
Cruise-In V Veteran
Not to concerned about drags, I want primarily a road race car. so between 4K-6.5K for a couple of hours is the goal
Old Jan 15, 2005 | 02:14 PM
Twin_Turbo's Avatar
Twin_Turbo
I would not use a serpentine if you plan on revving high, it may be nice for less drag but if it snaps you loose everything at once.
Old Jan 15, 2005 | 04:33 PM
84rzv500r's Avatar
84rzv500r
Radius Tooth Cog Belts
Old Jan 15, 2005 | 04:57 PM
Twin_Turbo's Avatar
Twin_Turbo
ahh htd belts
Old Jan 15, 2005 | 05:15 PM
Solid LT1's Avatar
Solid LT1
I use my "stock" LT-1 deep groove pulleys with a smaller diameter billet aluminum crank pulley to reduce the water pump speed to 100% of crankshaft speed and it works well to 7500 RPM.
Old Jan 15, 2005 | 05:40 PM
Taijutsu's Avatar
Taijutsu
I really like the radius tooth cog belt set up. How much does it cost and will it work on my 74 w/AC? TIA
Rick
Old Jan 15, 2005 | 06:24 PM
Guru_4_hire
Cruise-In V Veteran
Rick
that is pretty sweet.
Do you have a link for such a thing
To Accessory drive
