Cold Air Box
Old Jan 16, 2005 | 05:34 PM
jpatrick636's Avatar
jpatrick636
Default Cold Air Box
I am thinking of making a cold air box back to the windshield on my L-88 hood and am looking for ideas. I would appreciate some pictures.
Old Jan 16, 2005 | 06:50 PM
7t2vette's Avatar
7t2vette
The ORIGINAL and bestest
Toronto Events Coordinator
I am not trying to be a smart azz, but what about the using the air box made for the L-88 hood? Thats what I have on my L-88 hood, and it works great.
Old Jan 16, 2005 | 07:05 PM
jpatrick636
No offence taken. I'm not sure that would fit my application (502 w/dual plane manifold) but you're right, it is worth a look. Do you have pictures?
Old Jan 16, 2005 | 07:35 PM
Marks69BB's Avatar
Marks69BB
What manifold are you running? I'm assuming it's a single 4bbl carb version. If the height of it is ~5.25" it will work ok.
Old Jan 16, 2005 | 08:26 PM
Jughead's Avatar
Jughead
Senior Member since 1492
From: Just because I'm paranoid doesn't mean people aren't out to get me...
St. Jude Donor '09
Old Jan 16, 2005 | 08:31 PM
GrandSportC3's Avatar
GrandSportC3
Cruise-In IV-V-VI-VII-VIII Veteran
St. Jude Donor '03, '06, '17
Here's what I built.. It seals against the hood and pulls the air from the cowl... Reduced the air temp in the air filter by 20+ degrees...
Old Jan 17, 2005 | 03:22 PM
redc3's Avatar
redc3
NICE! I BUILT VERY ONE VERY CLOSE TO THAT. BUT I TIG WELDED MINE AND I KEPT IT STRAIGHT IN THE BACK. I HAVE A HOLE FOR THE TOP OF DIST. BUT COVERED IT WITH RUBBER COVER FROM FORD DISTRIBUTORS. I RIVETED THE BOTTOM AIR CLEANER PLATE TO THE BOX. I LIKE YOUR RUBBER SEALS BETTER THAN MINE, I USED DENSE FOAM
Old Jan 17, 2005 | 06:01 PM
jpatrick636
Thank you all.
GrandSportC3, That's very close to what I was envisioning except in aluminium. What holds it to the carb? Am I correct in assuming that the square stock at the back is very close to the crossmember when the hood is closed. Is your seal some kind of automotive weather stripping? Do you have a picture of it up against the hood?
Jughead, Do you know if these are available in the aftermarket? I tried searching through all the standard Corvette suppliers and found nothing. Is that held on the hood by some kind of glue or is glassed in?
Marks69BB, My manifold is a Chevy Performance Parts High Rise HO. When you say 5.25", at what point are you measuring from? The top of the valley? Without measuring, I know I have about .385" clearance over the carb.
redc3, I sure would like to see some pictues of yours. What gauge did you use?
Thanks again!
Old Jan 17, 2005 | 06:08 PM
Jughead's Avatar
Jughead
St. Jude Donor '09
Check Ecklers.com That's where I got mine. About $100, I think. It's "glassed" in if you want to call it that. I used a 5 min epoxy in a few areas to get it adhered to the hood. Then I filled in all the spaces & openings around the perimeter with fiberglas resin.
Old Jan 17, 2005 | 07:30 PM
jpatrick636
Jughead, could you detect any difference in performance?
Old Jan 17, 2005 | 07:34 PM
redc3's Avatar
redc3
Default patrick
patrick i used 1/8 sheet aluminum, cut with a jig saw. i made the radius on a tree stump in my back yard, but its smooth youd never know it! like i said i riveted the filter base to the bottom sheet and it attaches just like stock air cleaner would. im new at this comp junk and will ask the better half to get her digital camera out. its polished and looks kinda cool. id still like to know what the rubber seals are he used.
Old Mar 1, 2005 | 05:29 PM
jpatrick636
redc3,
In case you are still wondering, I found some great sealing material at Cabelas. It's for sealing boat hatches. I've got plenty; if you want some, email me at jpatrick636@sbcglobal.net
Old Mar 1, 2005 | 05:35 PM
Jughead's Avatar
Jughead
St. Jude Donor '09
At low speeds no. I think the chamber was designed to work best at racing speeds. But anytime you can get cold air to a carb is a good thing.
Old Mar 1, 2005 | 06:07 PM
jpatrick636
Then, in the name of performance, we will just have to maintain racing speeds!
Old Mar 1, 2005 | 06:11 PM
Jughead's Avatar
Jughead
St. Jude Donor '09
I know Chuck Harman with his L-88 had some real life testimony on the benefits of the air box. I can only say that when I had my SB I could notice a change in the engine performance at 60mph+.
The air chamber isn't aligned with the BB carb so I can't say about the 454. I need to cut out the old chamber, realign a new one and glass-in.
Old Mar 1, 2005 | 06:23 PM
jpatrick636
OK. I have obtained some sheet aluminium and I have some sealing material. I notice that everybody used a droped air cleaner base. I was thinking of just going strait from the top of the carb back to the hood opening and sealing to the hood. Does anybody think the drop base would be of any advantage?
To Cold Air Box
