What springs do I have?
Old Jan 16, 2005 | 07:55 PM
70 LS1's Avatar
70 LS1
Default What springs do I have?
I was planning to swap out my front springs with 460's, but now I am not sure.
I counted the coils on my stock spring and came up with 7 coils. Are these stock springs or aftermarket ones?
What are the wire diameters of the different available springs?
Old Jan 16, 2005 | 08:04 PM
MYBAD79's Avatar
MYBAD79
St. Jude Donor '05
Look at this thread, that's where the photo is from:
http://forums.corvetteforum.com/showthread.php?t=992900
These are the 460lbs and 550lbs next to each other:
Old Jan 16, 2005 | 08:08 PM
Gordonm's Avatar
Gordonm
I have seen that picture before. The aftermarket ones are 7 coils. The stock ones are a few more coils. I think around 12 or so. I might be wrong but I know there is more than 7. The 460s in the picture above are 13.5 inches free standing. i did not measure the 550s but you can see they are shorter.
70 LS1's Avatar
70 LS1
Thanks for the pic. Looks like the 460's and 550's have the same umber of coils. What about stock?
Old Jan 17, 2005 | 09:39 PM
70 LS1's Avatar
70 LS1
So, I have pretty much decided my springs are not stock. Is there anyway to determine what they are?
Old Jan 18, 2005 | 07:28 AM
Gordonm's Avatar
Gordonm
Not really. If you want to get technical and have lots of weight the 460 is the poundage it takes to compress the spring 1 inch vs 550 lbs to compress the 550s 1 inch. That would be kind of tough to measure. Not sure if the wire diameter is the same. I could measure the wire dia. of the 460s since they are out of the car.
Old Jan 18, 2005 | 07:52 AM
Jughead's Avatar
Jughead
Senior Member since 1492
From: Just because I'm paranoid doesn't mean people aren't out to get me...
St. Jude Donor '09
Here's a pic of the stock 10 coil springs:
Old Jan 18, 2005 | 09:54 AM
mandm1200's Avatar
mandm1200
Jughead:
Any idea as to the spring rate of the 10 coil spring.
Old Jan 18, 2005 | 10:20 AM
70 LS1's Avatar
70 LS1
Please do. thanks.
Old Jan 18, 2005 | 11:03 AM
VBP's Avatar
VBP
St. Jude Donor '07,'13
Originally Posted by mandm1200
Jughead:
It was about 300.
Tony
VBP
To What springs do I have?
