Several members asked me about the wheel spacers that I'm using so I thought I just post this:
Important:
- spacers must be hubcentric to the axle AND rim
- when using 1" spacer the studs must be ground aproximately .010" so that the studs are flush or below the mounting surface
- ensure good contact on mounting surfaces, use a file if needed to get rid of high spots
- make sure you got the correct nuts (metric or US standard)
Spacers/adapters are available on Ebay, $150 for a set of four 1"
and this is what it looks like - 275-60-15 on original aluminum wheel with 1" spacer (need two more for the front):
I have not found a lot of support here for the use of spacers.
However, I used them for about 18 months with zero problems. I had them custom made out of billet aluminum base on very exact measurements. So, it can work and work well.
Your vette looks great, nice job! Are you using spacers any more? What kind of wheels are you using and how do you like them?
Important:
