Removing door panel
Old Jan 17, 2005 | 05:15 PM
72Tornado's Avatar
72Tornado
Default Removing door panel
Anything tricky at all about removing the driver's door panel from my 72? I removed the two screws at the top and loosened the two bolts that hold in the 90 deg clips at the bottom...any trick to pull it off?
Old Jan 17, 2005 | 05:53 PM
72Tornado's Avatar
72Tornado
TTT...anyone?
Old Jan 17, 2005 | 05:56 PM
vettepilot68's Avatar
vettepilot68
Not really...you have to take off the window handle and the door handle and lock ****. The clips on the handle and **** take a few minutes, but then it just almost falls off.
Old Jan 17, 2005 | 05:58 PM
gearheadz's Avatar
gearheadz
What about the door pull (2 screws), door handle and door lock **** ..... ?
Old Jan 17, 2005 | 06:10 PM
Corvus's Avatar
Corvus
I'm having the same trouble with the door lock ****. This may help
http://forums.corvetteforum.com/showthread.php?t=994029
Old Jan 17, 2005 | 07:18 PM
superdad60's Avatar
superdad60
mine 68 has a screw in the center and no clip
much easier
Old Jan 17, 2005 | 08:24 PM
toolking's Avatar
toolking
Here's a link showing the tool you need to get the lock **** off.
http://www.madvet.com/shop?frame=1.1533
Old Jan 17, 2005 | 10:52 PM
Hazmat 13's Avatar
Hazmat 13
Navigator
I can get my door off easily - but can't seem to get the plastic clips (like solid velcrow) to stay engaged. Real tired of the door panel coming loose all the time. Any clues what to do?
To Removing door panel
