Show car accessories...
Old Jan 17, 2005 | 06:52 PM
vetteguy75's Avatar
vetteguy75
LA Events Coordinator
Default Show car accessories...
This past weekend I participated in the World of Wheels (got 2nd place in my class - Sport Domestic...pretty proud of that!). Anyway, I have a vert and, in order to really see the interior, I kept my door slightly open. I noticed that alot of the guys that did this had stainless steel "door stops" that hooked to the door latch on the door and the other end to the latch on the body...it kept the door stable and you could open it any further or close it.... Where do you get these? I wanted to ask but kept forgetting and then the show was over! I thought about making one...one 57 T-bird used a coat hanger ....Any help would be GREATLY appreciated...I had to keep people from "closing" the door ....
Old Jan 17, 2005 | 07:02 PM
Aflac's Avatar
Aflac
Cruise-In 5, 6 & 10 Veteran
St. Jude Donor '09
I saw a guy with a stancion for his car info made from a set of 82 hub caps... they looked pretty cool...here's the best pic i have of it.
Old Jan 17, 2005 | 07:04 PM
jpatrick636's Avatar
jpatrick636
The only ones I have seen were cusom made.
Old Jan 17, 2005 | 09:30 PM
INTIMIDATOR ZO6's Avatar
INTIMIDATOR ZO6
I know which one's your talking about I have a set! They were given to me by a friend that displays his C4 at a lot of the "World of Wheels". I don't have a picture but maybe I can get one this weekend to post.
Old Jan 17, 2005 | 09:38 PM
carl a's Avatar
carl a
i made my stantions outta 2'' pvc pipe.1 end has the cap the other end goes into a plumbing flange that i bolted to a 12'' piece of circular plywood.. i made6 of these and i attatch plastic chain to them using ''s'' hooks.theni made lights 3 sets outta flood lights and par holders and also bolted them to 12'' plywood circles.. also use a 400watt light from a light pole.then there are plexiglas mirrors i bought and had cut into 2' pieces,,so i got 4 outta a 4x8 sheet of mirror,---------
Old Jan 17, 2005 | 11:08 PM
74-Roadster's Avatar
74-Roadster
St. Jude Donor '06
Father & Son St. Jude Donor '09
Originally Posted by vetteguy75
. . . I noticed that alot of the guys that did this had stainless steel "door stops" that hooked to the door latch on the door and the other end to the latch on the body...it kept the door stable and you could open it any further or close it.... Where do you get these? . . .
Check out the street rod forums and street rod magazines. I've seen them advertised before. Typically they are just an aluminum bar with machined ends or bent hooks on them. I plan on taking an aluminum rod to a machine shop and have them machine the ends to fit my latches. I may even give it a shot myself with my crude tools.
To Show car accessories...
