Got lift??
Jan 17, 2005 | 08:52 PM
Cruise-In IV-V-VI-VII-VIII Veteran
St. Jude Donor '03, '06, '17
Got lift??
Jan 17, 2005 | 08:54 PM
Cruise-In VI Veteran
St. Jude Donor '08-'09-'10-'11-'12
Got Lift???
Yes, but mine has 4 posts and can LIFT 12,000lbs.
Jan 17, 2005 | 08:59 PM
Quote:
Jan 17, 2005 | 09:04 PM
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
Keep a close eye on that valve train, it takes a long time for solid roller stuff to settle in I adusted mine 5-6 times so far
Jan 17, 2005 | 09:16 PM
Jan 17, 2005 | 09:20 PM
Quote:
Will do
Jan 17, 2005 | 09:41 PM
Cruise-In VII Veteran
St. Jude Donor '07
Got coil bind... Man that is compressed. Thank god you got that cradle to keep those studs in. Way to go GS, I now know your serious.
Jan 18, 2005 | 08:23 AM
Are those single springs ?
Jan 18, 2005 | 09:15 AM
Cruise-In III Veteran
St. Jude Donor '05
Jan 18, 2005 | 09:19 AM
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
Good looking stuff there Oliver. I missed it, did you get your new engine already? When is it going in?
Jan 18, 2005 | 10:26 AM
Eddie, I got the engine already on Friday but only posted about it yesterday.. It's going in shortly after I get the car back..
Jan 18, 2005 | 12:27 PM
2 springs
I saw it also.
Jan 18, 2005 | 12:28 PM
2 springs
I saw it.
Jan 18, 2005 | 12:56 PM
They are actually double springs...but the photo makes them look like they are single springs...
Will try to get a better shot tonight...
Jan 18, 2005 | 12:58 PM
you can see the diff. it looks closer to bind because of the inner spring
Jan 18, 2005 | 01:02 PM
[QUOTE=GrandSportC3]
You know what I got.
Not as good as that, but aint' too shabby.
(BTW, what IS my lift?!
Just kidding, I saved the spec. somewhere.
Jan 18, 2005 | 01:07 PM
As soon as you can I would like to see the job they did on the roll bar. I would love to see how they welded it to the frame.
Post some nice pictures and tell us a little details.
Jan 18, 2005 | 01:11 PM
Mark, the specs on your cam are:
238/248 degrees duration @.050 and .525/.540 lift. That's with the 1.5 roller rockers. If you'd want to go with 1.6 ratio rocker arms, you'd need new springs because the current ones would coil bind.
Jan 18, 2005 | 01:14 PM
I can't wait to see the finished rollbar too..
Jan 18, 2005 | 06:25 PM
Just took another pic of the springs.. My camera sucks for closeup pics..
In this pic you can see the 2nd spring inside.. Checked the compressed spring again and it's far from coil binding.. The pic is just bad...
The thing that looks like a shadow on the spring is actually the 2nd spring below.. It's difficult to get a good angle on the spring..
