What spacer do i need?
Old Jan 18, 2005 | 04:54 PM
81corvettevortec's Avatar
81corvettevortec
Default What spacer do i need?
I am wondering if any of you guys would know how think of spacer i would need to put the 17 inch zr1 rims on my 1981 corvette? thanks for any info!!!
Ryan.
Old Jan 18, 2005 | 04:58 PM
Schmucker's Avatar
Schmucker
You will need wheel adapters. Probably something like 2" adapters. The offset difference is quite great. VBP can probably tell you exactly.
Old Jan 18, 2005 | 05:28 PM
VBP's Avatar
VBP
St. Jude Donor '07,'13
What year ZR1 ?
Tony
VBP
Old Jan 18, 2005 | 05:30 PM
81' Corvette Guy's Avatar
81' Corvette Guy
Need before and after pics bro..might as well throw in "as you go pics" too...hehe! Thanks, Joe!
Old Jan 18, 2005 | 05:56 PM
81corvettevortec
the rims that i am wanting to put on are the ones floating around ebay, the offset on them is 56mm. also will a 17-9.5 fit at all 4 corners? thanks again.
Ryan.
Old Jan 18, 2005 | 06:00 PM
MYBAD79's Avatar
MYBAD79
St. Jude Donor '05
There is one photo of a silver Corvette on www.afswheels.com
http://www.afswheels.com/v2/Customer...nfo&userID=393
http://www.afswheels.com/v2/Customer...nfo&userID=483
I have 11X17 ZR1 wheels on my Camaro, I never tried to install them on the vette... I'd say you need at least 2.5" spacers/adapters for the rear....
If you want to install the 9.5X17 wheels then 2" front and 2.25" rear will be fine, that's what the guy with the blue Corvette installed (link above)
Make sure your spacers/adapters are hubcentric to BOTH, axle AND rim !!!
Here's some info on spacers/adapters:
http://forums.corvetteforum.com/showthread.php?t=993302
Old Jan 18, 2005 | 06:09 PM
corvetteatv7's Avatar
corvetteatv7
I don't believe a 17x9.5 will fit in the front unless you get and oversized adaptor and then your wheel will stick out the side of your fender and will have problems with rubbing and so on.
Old Jan 18, 2005 | 06:16 PM
MEGALADON's Avatar
MEGALADON
From: WAY DEEP INSIDE AMERICO,YES YOU LIVE HERE TO!! TX
IMHO, C-3's with that much positive offset don't look right.
Old Jan 19, 2005 | 01:28 AM
81corvettevortec
From what i have seen, you can't get the zr1 replica rims any skinnier than 9.5? and some people are still using them. thanks.
Ryan.
Old Jan 19, 2005 | 01:51 AM
gkull's Avatar
gkull
You have to find out the back spacing of the Wheel. I ran 1 inch adapters with 9.5's and and 2 inch with my 11X17 rears.
You also have to think about 550 # front springs so they don't hit body and mine brush the 1.1/8 sway and frame on full lock. Not a big deal just don't do it.
You car will handle like a go kart with correct alignment with sticky wide low profile tires. Just step up to the plate and do it :o
Old Jan 19, 2005 | 12:44 PM
IronJen's Avatar
IronJen
Abby Normal
Veteran: Marine Corps
i got the 2.5" front and 3" rear wheel adaptors from VBP years (and years and years ago). i haven't had a problem with them but i can tell you a couple things.
1) you will never get true ZR-1 rear wheels to fit without some sort of reconstructive surgery.
2) 8.5" front is preferable for clearance issues. i will run the 9.5" on the front for track events and i do get some contact with the inner fender well and sway bar at full lock. 2.5" with a 245/40-17 on an 8.5" wheel in the front is probably your best combination. probably also your best combination in the rear also.
3) on the rear, the 8.5" rim on a 3" adaptor is just barely within the fender lip (very cool). 9.5" on the same adaptor is just barely outside the lip.
4) as long as your suspension is tight and relatively stiff, you shouldn't have any problems with rubbing the fenders.
if your interested, i have multiple pictures with both 8.5" and 9.5" wheels on my car.
what i believe your looking for (or maybe should be) is the '96 GS convertible or collector edition wheels. those would be the most correct wheels for what you want to do.
Old Jan 19, 2005 | 07:08 PM
81corvettevortec
Thanks a lot everyone! if you wouldn't mind sending me those pics, that would be awesome! it will give me a idea on what look i want! thanks again.
Ryan.
Old Jan 19, 2005 | 09:58 PM
IronJen's Avatar
IronJen
Abby Normal
ryan, if you want pics, i need an e-mail addy. lost all my hosted pictures when photohost went away.
Old Jan 19, 2005 | 10:04 PM
AGVI's Avatar
AGVI
Canadian Events Coordinator
Doesn't look that great.
To What spacer do i need?
