Jim, (427HotRod) you were on the right track! Check out the pics.
This is NOT Olivier's fault. I volunteered the fuel pump rod from my L48 so we could use the one from the 383 for a tool while removing the motor.
I found this while I had the pump out when I was re-routing the fuel lines, getting rid of the rubber elbow and fabricating a metal one. I had to twist and pull the rod out with pliers. I'm sure it came out of the L48 that way and I didn't notice it because when I was installing the pump, I put some grease on the rod and pushed it up in the hole. It held the first time without sliding down, even though I was struggling with the pump. I was sure I nudged it with the pump, but it didn't drop and thought I had put just enough grease on it.
Now the solution: I think I'm going to need an electric pump. I'm going to have some questions about how to set that up. I don't know if the cam lobe that pushes it was damaged, but I'm not going to take a chance. I wonder how long the L48 was running with it in that condition?
The car drives completely normally around town and even getting on it. Funny how this symptom didn't completely manifest itself until I went to the track.
I wonder if the Holley Black pump at 120 Gph and 9psi line pressure will be enough for my motor? Is 9 PSI correct for my carb (4150 Holley 750) or will I need a pressure regulator too?
I was told by many people that you shouldn't go over 7 psi fuel pressure with a Holley carb..
From: Las Vegas - Just stop perpetuating myths please.
Nice catch.
Now i can c y fuel press indication is do popular. Many racers use a press gauge mounted in front of windshield. Holley now sells an electric for only $75 (Summit).
Good luck and thx for posting. cardo0
i would replace the rod. that's why they sell them!
Matt, I was thinking of that. But you wouldn't believe how much force I had to use to get it out. It was really stuck and I don't know how it was even moving the pump. Now I'm worried that it may have worn down the lobe that drives it.
The car drives fine around town. But I can't really get on it like I do at the track and that's where the problem shows up. It's tempting. Does the imformation I just posted make a difference?
just put in a new one and try it. if it doesn't bind, a quick test drive will tell.
electrics' are noisey and less reliable and can keep running in an accident if not wired right.
Interesting find...glad it wasn't anything too serious. I just installed a new pump rod in my 383, didn't grease or oil it..and it just stuck up there and stayed..Its been bothering me lately..I haven't installed the pump yet. I think i need to take it back out and lube it up some grease or oil?
Holley pumps are the loudest on the market...for street use the HOlley will drive you crazy....
Mallory are much quieter, and Aeromotive, think they are the quiet ones.
Regarding the wiring, simple task..ground, inline fuse and a hot lead to ignition....nothing to it.
I don't trust electric pumps so I always run two. Each to a seperate switch and like a plane I check each one regularly.
Holley pumps can be made quiet. There are special mounting brackets that are rubber mounted. I do not hear my twin pumps.
Our local screw company Spanaur sells vibration dampers in different sizes and one works well for our pumps.
It is two metal flanges, right bolt pattern for our pumps and seperated by 1 in of rubber.
As I said before I also don't like mechanical pumps if they rupture the diagram they flood the motor.
These are old ones, but I put a bolt in the center and attach it to the frame and bolt the pump to the flange with the 2 holes.
Quiets the pump down enoght that you don't hear it at all when then motor is running and while priming the motor before starting just a slight buzz
I'll sell you a Holley "blue" for $50 shipped to you! I have a bunch of these pumps from my childhood "Drag days". I run a Carter NASCAR mechanical pump on my 12.28@117 MPH 72 LT-1 myself but, what the heck do I know about Drag racing as I mostly autocross my Vette. Email me fo Holley red/blue pumps, I would love to get rid of some!
I had a Carter 130 gph mechanical, but now I'm worried about the cam where it drives the pump pushrod. I figure the electric pump will eliminate that possibility, and maybe free up 1 HP, but eat 1/2 at the alt.
