C4 steering col. in a C3?
Old Jan 19, 2005 | 12:46 AM
sharkman76's Avatar
sharkman76
Default C4 steering col. in a C3?
Will it fit? What if any mods. to make it fit? Anybody done it?
Old Jan 19, 2005 | 12:49 AM
lostpatrolman's Avatar
lostpatrolman
Why would you want to?
Old Jan 19, 2005 | 08:12 AM
markdtn's Avatar
markdtn
THe C4s use a rack and pinion and I'm pretty sure that the length is substantially different. What would be the advantage?
Old Jan 19, 2005 | 09:24 AM
BBShark's Avatar
BBShark
St. Jude Donor '05-'07
A C4 column will fit in a C3. All of the attachment points need to be changed (at firewall, new column support bracket, etc). C4 columns aso use a double D shaft and C3' are splined so you will need a new rag joint. The biggest challenge is wiring the ignition switch and other stuff (wipers etc.). The wiring isn't so bad but finding the connectors from a C4 harness is difficult. A C4 column with wheel (from a 94-96) is actually slightly shorter than a C3. An earlier C4 column is slightly longer.
To C4 steering col. in a C3?
