Leaking Tranny pan.
Originally the leak was bad, so I replaced the gasket, complete with gasket adhesive. It leaked again. Second time, I tapped flat the bolt holes in the pan, and installed a rubber gasket. Yup, another leak. Third time, I purchased a cast aluminum pan, and re-installed with rubber gasket. Much less leaking, but still a leak. Fourth time I sealed the pan using only Permatex Black RTV sealant. Less, leaking than ever, but still a leak. When I disassembled this last time, it looked like I mught have tightened just a bit too much, and that where it leaked the RTV had been squeezed pretty thin. This time I resealed with Permatex, The Right Stuff, which says its recommended for ATF fluid, and is supposed to be the ultimate seal. I only tightened the bolts on lightly allowing for lots of goop left between pan and tranny.
I'm now going to give it a couple of days to set real good. Then I'll try again.
Before you guys suggest looking for cracks in the casing, or leaking from the torque converter seal, or leaking from the TV cable, or dipstick entry point. All that's been done. This time I'm keepin my fingers crossed.
Anybody else ever experience anything like this?
Thanks for the reply guys. I'll try the 100 inch lbs. torquing next if this, (sigh) doesn't work.
I did check seals around the pan, TV inlet, dipstick etc.. It was definitely leaking from the mating surfaces. The mating surfaces are straight. I installed this tranny, in lieu of the TH350, and the pan is heavy cast and polished aluminum. The sealant is supposed to seal up to 1/4 " gaps. But....... I never did torque the pan on. Hopefully this'll work. We'll see when fill er up again. (not real anxious to find out).
BTW, my 700R4 came from Bow Tie. Once I knew the problem, they sent the new selector shaft and seal without hesitation.
the bolt holes flat and used an impact wrench to tighten. You develop a feel for how tight and never had any pan leak. You should have even less worry with a rigid aluminum pan. As the others have cautioned though, transmission fluid can travel around and down from other sources and make you think it's the pan, particularly the front pump o-ring which is notorious for leaking while sitting overnight. The front seal will almost always leak while car is running if it's bad. The shift linkage seal also leaks overnight. The only way to be sure is to carefully wipe it down and inspect it with a light after it sits for several hours. Good luck.
I always use a cork gasket, a thick one. There have been times when I've made my own. Also never used sealant. Never had a problem. If sealant is needed, something is wrong. Beside, it will never last like a good gasket will. Also, while reading this, my first thought was the selector seal as well. It can be difficult to tell the difference sometimes.
