Mono Spring Mounting Torque
Old Jan 19, 2005 | 10:46 PM
Edzred72's Avatar
Edzred72
Default Mono Spring Mounting Torque
Almost ready to put my entire rear suspension back in. Rebuilt & painted everything BUT...with what torque should I tighten the four bolts of the rear fiberglass spring to the differential??? 355LB AO Smith (made by TRW)
Thanks as always
Eddie
Old Jan 19, 2005 | 11:16 PM
Uncle Ralphy's Avatar
Uncle Ralphy
Default TRW torque
I installed a TRW 340 rate about 3 months ago. The instructions said to torque evenly to 15, then 30 and finally 50 foot pounds. The same torque applies to your 355 rate as well.
Old Jan 19, 2005 | 11:19 PM
73jst4fun's Avatar
73jst4fun
Old Jan 20, 2005 | 12:07 AM
lostpatrolman's Avatar
lostpatrolman
you are supposed to tighten in an X pattern right?
Old Jan 20, 2005 | 11:27 AM
Edzred72's Avatar
Edzred72
Thanks for the replies guys. Spring was on when I bought the car so no info on hand.
Eddie
Old Jan 21, 2005 | 11:02 AM
vettedesk's Avatar
0vettedesk
Supporting Vendor
45-50 Foot pounds is needed on those four bolts. If you have any questions or concerns we are the Manufacture.
Vettedesk
Muskegon Brake
(800)442-0335
vettedesk@muskegonbrake.com
Old Jan 21, 2005 | 11:05 AM
ylose's Avatar
ylose
Sounds like your getting far Eddie ! What color combo did you go with? and what was the winning paint vendor for the fiberglass spring?
Old Jan 21, 2005 | 11:41 AM
Edzred72's Avatar
Edzred72
Hey J I went with POR-15 Silver on the half shaft shafts, (ends are black) plus the Strut rods & bracket. The rest of the rear components & frame is Eastwood Chassis black over a POR-15 black base.
I figured if Colorcoat bumper black is good for flex bumpers...it's good enough for my fiberglass spring. Turned out GREAT!! Almost perfect match to the original finish. No pics yet...cause everything is still laying all over my basement. Waiting for my rebuilt spindles to come back too before putting it all back together.
Eddie
Old Jan 21, 2005 | 03:00 PM
Van Steel's Avatar
Van Steel
Premium Supporting Vendor
Correct. If you run each bolt up all the way and not do the x pattern method you have a very good change of breaking an ear off the diff.
Old Jan 21, 2005 | 03:09 PM
Jack71's Avatar
Jack71
I thought you were supposed to retorque the bolts to spec once the spring is under load & flattened out.
To Mono Spring Mounting Torque
