I just finished putting the rearend back in my 78 and was wondering about 3" exhaust. 1. Can it be bent and routed correctly? (under the rearend = tight curves) 2. Has anyone setup their exhast so it's removable? I was thinking about getting some collector flanges and placing them after the holes in the frame, bolted together so I could remove the exhuast as needed. I had to cut mine to remove the pipes for rearend work... 3. What mufflers produce the best sound for a 350?
Unless you are running a hot big block stay with the 2 1/2" or you will lose all your bottom end torque-----I have a 440hp 383 and headers throught 2 1/2" w/ flowmaster 40's and it's definitely plenty........I don't know if 3" pipe will fit through the stock crossmember area???? 2.5 is pretty tight as is......although I am sure 3" would sound great.....good luck..
yea, the 3" i would think would scrape the ground alot. 2 1/2 is the proper size for just about any small block. Flowmaster 40's sound great if you can put up with the rumble all the time. The 50 is a little milder. I have dynomax super turbo's and love em. Check out http://exhaustsoundclips.com/
nice sounding vette! i dont wanna get in the way here but ive been thinking about using a flattened X or H pipe under the diff where the 2 pipes come together ang go up to the muffs. think this would be really trick. ( heh heh... he said muffs )
Thanks in advance...
I have a Stainlessworks 2&1/2 " Stainless mandrel bent. I am about to install an X-pipe under the rear diff. I will be putting ball/socket joints at the middle crossmember to make the rear removable. Most aftermarket systems never seem to squeeze together enough when they pass under the rear end (diff). The factory had this fairly close together and flattened the pipes also.
My idea of a perfect system would be headers then a fully mandrel bent system that transitioned into a OVAL pipe under the diff then back to round just before the mufflers. Mine won't be as ideal as I don't have headers but I will have an x-pipe fited pretty snug to the diff. I may have to use 45s like Gdaina suggestes so that I can get the angles right back there.
If I had to do mine again I would have taken my car to a shop with a mandrel bender and told them what I wanted and paid to get it done nice and snug.
Here's a 3" exhaust system I'm currently building. After the X-pipe under the rearend it reduces to 2.5" .... I'm still working on this portion of the system. I'm using Borla mufflers and Car Chemistry inserts in the pipes at the transmission crossmember. The only place the pipes hang below the frame are right in front of the rear tires as they pass under the rear crossmember just infront of the rear end. This system actually fits tighter against the underneath of my car than my previous 2.5" system.
