Leaking 75 convertible.
Old Jan 22, 2005 | 09:48 AM
62fuelie's Avatar
62fuelie
Default Leaking 75 convertible.
Aside from the usual leaks around the top, which I know how to deal with, my 75 is leaking from somewhere around the cowl. Some previous owner has applied sealer over the entire area, so it's sort of hard to tell where the leak may be. Is there a particular spot on C3 cowls that is a known trouble spot. C2's have a propensity to leak where the cowl and firewall panels are attached, just wondering if the C3's have the same sort of issue. Any advice would be appreciated.
Old Jan 22, 2005 | 11:48 AM
phclub's Avatar
phclub
New England Events Coordinator
Default Leak
See thread: ~Easiest way to fix a leak?~
Old Jan 22, 2005 | 04:13 PM
markdtn's Avatar
markdtn
Do a search on leaks and you may not like what you find. Sounds like your WS frame is rusted out. This is a common problem for C3s.
Old Jan 22, 2005 | 04:52 PM
62fuelie's Avatar
62fuelie
Sort of doubt it's the ws frame. I can pour water directly in the cowl area and it will come through from somewhere. However, I may pull the ws and look just to be sure.
Old Jan 22, 2005 | 08:03 PM
markdtn's Avatar
markdtn
The mounts for the wiper arms also can leak. Take 2 of the 3 screws out (loosen the 3rd) and silicone behind the mount. There is a plate that can fall out if you remove all 3.
To Leaking 75 convertible.
