Header install Labor Costs??????
Old Jan 22, 2005 | 12:38 PM
OneBrokenSmile07's Avatar
OneBrokenSmile07
Default Header install Labor Costs??????
I was planning on purchasing a set of Dyno Headers as the board population swears by them, but when I went to a local mechanic (The same guy I've been bringing my car too, and trustworthy) Says it will cost around 600 in Labor alone!!
That's rediculous. What did you guys pay to have em put in, or did you do the work yourself?
I can't afford to let the car sit for weeks while I do the work myself, so I kind of am in a jam.
Old Jan 22, 2005 | 12:44 PM
carl a's Avatar
carl a
i dont see why it should cost so much- those ram horns came right off my car when i took them off to get jet coated. the headers should bolt right up. maby he is figuring time on connecting the headers to your exhaust or something else like that
Old Jan 22, 2005 | 01:07 PM
Gordonm's Avatar
Gordonm
It is not that bad of a job. Just labor intensive that is why the cost is so high. Also anything can come up and you are putting on custom parts. Nobody on flat rate likes to do custom jobs. They lose their shirt most of the time because it does not fit or something is missing. I do everything on my car for that reason. It is done right and to my standards. I have the rear out of it now because somebody else set up the gears and they are not right. If you have the time do it yourself.
Old Jan 22, 2005 | 01:15 PM
redc3's Avatar
redc3
those headers are not a bolt in, as your existing pipes will have to be made to fit your new headers and collectors. and that old stuff can be a real bear to remove if your trying to not hurt parts. if he does a quality job, id have to say its fair. id do it myself.
Old Jan 22, 2005 | 02:31 PM
rexx78's Avatar
rexx78
I was quoted a full day labor, so I did it myself. The shop had done it before and knew there were some fit problems. It took me about 6 hours to install my Hedman's by myself. I had to lift the engine, remove the starter and Z-bar (4 speed). It would have taken a lot longer if anything was rusted in place, or if I hadn't already removed the engine twice before. The coolest part is driving to the muffler shop with open headers.
Old Jan 22, 2005 | 03:32 PM
markdtn's Avatar
markdtn
If you supply the parts there is no upside for him. He is pricing it high enough where if there are problems he is covered. If you buy the headers through him the whole deal might be less. Worth a try.
Old Jan 22, 2005 | 03:52 PM
76texvette's Avatar
76texvette
It took me about 6 hrs to do mine. Of course, I already had 15 yr old headers and the Dynomax Ceramic looked identical. The passenger side went in with no problem except for getting the A/C compressor out of the way. The driver's side I had to remove the oil pressure sensor. After that I was able to hook up to my old exhaust. Automatic transmission helped too.....no clutch linkage in the way.
Old Jan 22, 2005 | 08:05 PM
Fastbackl48's Avatar
Fastbackl48
I left the ram horn manifolds on my '79 since the engine was only putting out 195hp. If you are planning to put true duals on, then get headers. But the cheapest performance upgrade I made to my '79 had nothing to do with the engine. Ditch the spare tire, and ditch the heavy metal rear leaf spring for a fiberglass one. I felt the difference with 100lbs ballasted off the car. The ride will also be a lot smoother.
Old Jan 22, 2005 | 08:12 PM
LFZ's Avatar
LFZ
THat seems like an extremely high labor cost considering, its not that bad of a job. Maybe its more dough because its a Vette?? i've actually heard that excuse before too.
To Header install Labor Costs??????
