TPI users.....
Old Jan 22, 2005 | 05:22 PM
toyvet1's Avatar
toyvet1
Default TPI users.....
Do you that are running TPI systems are you using a vechile speed sensor. Any pro or cons....
Old Jan 22, 2005 | 05:34 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
You need a VSS of some sort to make the system work properly. Look in the GM-ECM section at www.diy-efi.org for more info.
Old Jan 22, 2005 | 07:09 PM
toyvet1's Avatar
toyvet1
Link doesn't work?????
Old Jan 22, 2005 | 07:15 PM
PatsLs1vette's Avatar
PatsLs1vette
yes use the vss,the vss controls alot of functions,i just recently swapped from the stock one to a painless wiring one.
Heres an excerp from chevy thunder
You must be able to use the VSS (vehicle speed sensor) with your tpi setup, even if you don't use a overdrive transmission. The VSS is needed because many tpi functions are directly related to it, such as idle speed and A/F ratio, etc. There are aftermarket suppliers such as B&M that has a speed sensor kit so you can use the VSS.
Don't count on top performance from your TPI without it.
Old Jan 22, 2005 | 07:52 PM
markdtn's Avatar
markdtn
Yes, you need VSS. You may have stalling problems coming to a stop without it. You can get them from Howell, Street and Performance, Painless (Jegs/Summit), Jags That Run, Fuel Injection Specialties, Etc.
Old Jan 23, 2005 | 12:05 AM
toyvet1's Avatar
toyvet1
I have a Howell harness in the car now without it. I'll have to get ahold of them and find out how to update the harness for one....
Old Jan 23, 2005 | 06:04 PM
markdtn's Avatar
markdtn
Howell sells harnesses without them. They have you adjust the throttlebody so it doesn't stall. You will need a bit more harness and a PROM reprogramming. My opinion is that it is worth it. Maybe they will reflash your PROM free since you bought the harness from them.
Old Jan 23, 2005 | 07:02 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
I'm not sure what happened to the page - I'll see what I can find out. Personally, I wouldn't eliminate the VSS - it's there for a reason - if the job could be done better without it, it wouldn't be there.
Old Jan 24, 2005 | 12:18 AM
timbo79's Avatar
timbo79
THis is what you need:
http://store.summitracing.com/defaul...e+speed+sensor
PAINLESS PRF-60116
Old Jan 24, 2005 | 07:42 AM
PatsLs1vette
Just remember theres 2 different vss's for tpi,youll need to know your year.
Old Jan 24, 2005 | 07:50 AM
markdtn's Avatar
markdtn
Yes, Mass-Air type is 2000 pulses per mile
Speed-Density is 4000 pulses per mile as is LT1 and Throttle-body
Old Jan 24, 2005 | 11:18 AM
Sarge81's Avatar
Sarge81
I have a couple of questions about TPI in a C3 myself.
My vette is an '81. I'm gathering all the parts and pieces for a TPI system for my car. The question is, am I better off getting a tank and sending unit out of an '82 crossfire injected vette?
Or would it be safe to use an inline pump and put a return line in the existing sending unit and use the original tank? I'm just worried about fuel starvation problems.
Thanks in advance. Darryl
Old Jan 24, 2005 | 11:26 AM
PatsLs1vette
youshould be able to put a 82 sending unit in yours with the right pump and use your existing lines if there in good shape.You should use 3/8 feed and 5/16 return.
Old Jan 24, 2005 | 12:11 PM
markdtn's Avatar
markdtn
Yep, use an 82 sending unit and aTPI pump and it will be easy. Do a search on TPI and you will find a lot of info in the archives on this conversion.
Old Jan 24, 2005 | 03:51 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
If anyone is interested, the diy-efi page seems to be alive and kicking again. The GM-ECM section has a lot of info on modifications/retrofits of factory GM fuel injection.
Old Jan 25, 2005 | 11:14 AM
Sarge81's Avatar
Sarge81
Thanks guy's. I will check in the diy-efi section.
If I can get away with just the sending unit/pump assy. that would be great. I see that '82 tanks are hard to get due to the sump inside and nobody repro's them. And they are also pricey.
Darryl
Old Jan 25, 2005 | 11:38 AM
Twin_Turbo's Avatar
Twin_Turbo
I have a tank and sending unit but it will be expensive to ship.....too bad.
As for the VSS issue, why not install a GM one, all 82 & 81 vettes have a VSS screwed into the back of the speedo (it's an optical emitter & sensor combo that shines into the back of the speedo, then a rotating mirror - conencted to the drivecable - spins and the optical sensor pics up the signal), all TH350C (lockup) cars have one also. It's a blue or yellow box with a small flat cable on it w/ green, black & a brown wire.
Here's the wires:
back of cluster, VSS clearly visible:
optical emitter/sensor
screws into this: if yours down's have a threaded hole use a self tapping screw
Here you can see the mirror "rotor" part
To TPI users.....
Old Jan 25, 2005 | 02:08 PM
Fevre's Avatar
Fevre
I would gladly pay $100 to NOT have the pull the dash apart to install that GM system..
Old Jan 25, 2005 | 02:11 PM
Twin_Turbo's Avatar
Twin_Turbo
What's hard about installing that? You lower the column a but, don't need to lower it to the seat, just undo the 2 bolts a bit then remove the cluster, it's a couple of screws a speedo cable and a harness connector. Can be done in say 15 minutes.
Old Jan 25, 2005 | 02:17 PM
Fevre's Avatar
Fevre
Mine was a pain in the ARS to reinstall with mech speedo and tach not to mention all the little dash bulbs that seem to wiggle free plus I must have pinched the headlight switch hoses because it worked when I tested it before putting the dash on and then the lights did not come up after it got it together.
