Turbo 350 Trans Help
Old 01-23-2005, 12:25 PM
BTRNSEX
BTRNSEX's Avatar
Default Turbo 350 Trans Help
I have a 79 L82 with a turbo 350 trans. The problem is when I shift from park to drive I get a hard bang. I first thought U joints or Rear diff.....NOT!! Turns out the output shaft of the trans goes counter clockwise ever so slightly then snaps back clockwise.
Anyone know if this is a linkage problem or maybe valve body problem?
Any help is abpreciated.
Old 01-23-2005, 06:54 PM
bobs77vet
bobs77vet's Avatar
Location: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
have you checked the mounting pad on the front of your differential? next time look the other way and see if the differential is moving when you put it in gear.
Old 01-23-2005, 09:41 PM
EVIL_GRIM
EVIL_GRIM's Avatar
do you have a high idle? cuz that will cause you to get that nice "bang/clunk" when entering Drive/ i gett hat in my newl rebuilt tranny, but my idle is like at 850.
Old 01-23-2005, 09:54 PM
BTRNSEX
BTRNSEX's Avatar
Thanks.
Idle is 650rpm, and the rubber pads are new ae well as reans and motor mounts.
Old 01-23-2005, 09:55 PM
BTRNSEX
BTRNSEX's Avatar
Thanks.
Idle is 650rpm, and the rubber pads are new are well as trans and motor mounts.
To Turbo 350 Trans Help
Quick Reply: Turbo 350 Trans Help
