need help identifying heads and manifold
Old Jan 24, 2005 | 02:07 PM
greyghost79's Avatar
greyghost79
Default need help identifying heads and manifold
need forum members help. 79 L82 BUT modified with aluminum heads and aluminum intake manifold.
part numbers
manifold - 14007378 with the letters GMCM underneath
heads - 14100128 with the letters F2 above and SR below.
are these both GM parts??? what spark plugs should be used with these heads? gap? (i'm running MSD digital 6 ignition also), headers with true dual exhaust, no pollution controls. what kind of compression should i be getting? HP estimate?
thanks for any and all info.
Old Jan 24, 2005 | 06:55 PM
greyghost79
Old Jan 24, 2005 | 07:45 PM
Patrick73's Avatar
Patrick73
Casting Number 14007378 is late 1979 L-82 intake.
I do not belive the heads are C3 Corvette.
Old Jan 24, 2005 | 07:53 PM
greyghost79
i don't either. they are aluminum and i'm not aware of any aluminum on any late C3 engines. i thought L82 had cast iron manifold. mine is aluminum. how can i determine what the heads are from. is there a publication or website for these number?
Old Jan 24, 2005 | 07:54 PM
greyghost79
someone told me the heads were "probably" C4 heads but how can i determine this?
Old Jan 24, 2005 | 08:14 PM
markdtn's Avatar
markdtn
C4 alum headsare 14085964 or 14101127 86-89
or 10125374 for 90-91
Old Jan 24, 2005 | 08:27 PM
nostgry's Avatar
nostgry
Ghost - I'm not sure you got the right head #, I'm showing14101128 GM. This # is 86-87 Alum.- 58cc angle plug.
350. Go to www.mortec.com for accurate chevy casting #'s
Old Jan 24, 2005 | 09:55 PM
greyghost79
o.k. i did it the hard way. went to barnes and nobles and looked it up in the chevy small block parts interchange manual.
the book only has a one line entry. it says 14101128 are
86-87 aluminum, 58cc, angle plug heads.
can anybody tell me what the recommended spark plug for this head would be??
also, what compression ratio should i expect. and is there anything special or unusual about angle plug heads? why are they made that way?
Old Jan 24, 2005 | 10:38 PM
page62's Avatar
page62
The '79 L82 had an aluminum manifold. Bottom line: You have the original manifold with a set of L98 heads from an 86-87 Vette.
Old Jan 24, 2005 | 10:42 PM
greyghost79
what spark plug does the L98 use? is the combustion chamber the same as the 79 L82 chamber?
Old Jan 24, 2005 | 11:08 PM
comp's Avatar
comp
Hmmmmm
Old Jan 24, 2005 | 11:10 PM
feb18blacksunday's Avatar
feb18blacksunday
From: Boone NC home of 3peat National Champs ASU Mountaineers
St. Jude Contributor
How does the Vette perform with those heads?
Old Jan 24, 2005 | 11:17 PM
greyghost79
i don't like the low end, but the mid range rocks (2500 to 5000 rpm seems to be the sweet spot).
Old Jan 25, 2005 | 08:06 AM
markdtn's Avatar
markdtn
That head was originally used on a TPI engine that had all the low end you wanted. As far as plugs, start with stock 87 L98 Corvette as an application.
Old Jan 25, 2005 | 08:40 AM
page62's Avatar
page62
That has more to do with the original L82 cam than the replacement heads. The L82 doesn't wake up until it gets over 2000 rpm -- a good candidate for a higher stall converter (I have a 2200 stall unit).
The L98 heads were designed with TPI in mind. They have 58cc chambers (thanks to knock sensors it became possible), but they don't flow very well, nor do they have any features of the later Vortec heads. Basically an aluminum version of the classic stock small block head.
On the plus side, your engine is now an excellent candidate for a TPI swap.
Old Jan 25, 2005 | 06:49 PM
joe73vette's Avatar
joe73vette
CR depends on the pistons, you could be over 10.5:1 with flattops. I don't know if L82s came with dished pistons though. Joe
Old Jan 25, 2005 | 08:20 PM
page62's Avatar
page62
L82 engines had flat top pistons with a single indentation for the valves; ie., the pistons can only be installed with the indent facing up...otherwise...BAM!
To need help identifying heads and manifold
