Mechanical Vs. Electric Fuel Pumps
Old Jan 24, 2005 | 04:37 PM
JMoney454's Avatar
JMoney454
Default Mechanical Vs. Electric Fuel Pumps
I'm going to be replacing my fuel pump, and I was wondering if there was any real advantage to using an electric pump instead of the mechanical one. Any thoughts?
Old Jan 24, 2005 | 05:37 PM
AlwaysWave's Avatar
AlwaysWave
Cruise-In III Veteran
unless you need more than 6-9 lbs pressure, there's no need for the hassle of installing an electric pump.
Old Jan 24, 2005 | 06:44 PM
Tom73's Avatar
Tom73
No advantage on a stock engine.
tom...
Old Jan 24, 2005 | 06:59 PM
Gordonm's Avatar
Gordonm
These have worked fine for millions of miles. Unless you are pushing a ton of HP stick with mechanical. Even then it is marginal for a street car.
Old Jan 24, 2005 | 09:23 PM
C3 Stroker's Avatar
C3 Stroker
470 HP...383 cu. in....11.8 ET.......mechanical fuel pump, no problems. (170 GPH, Carter HP )
Old Jan 24, 2005 | 09:28 PM
C3 Stroker's Avatar
C3 Stroker
470 HP...383 cu. in.....11.8 ET.........mechanical fuel pump, no problems. (170 GPH, Carter HP, no regulator necessary)
Old Jan 24, 2005 | 10:58 PM
Ironcross's Avatar
Ironcross
With all of the above answers. All the high horsepower GM and Vette engines were equiped with a mechanical pump. 283/327/350`s from 283 to 375HP carb and FI SB engines and L88, ZL1, L71, 427`s plus LS6 and LS7 454`s. The exceptions are those engines with out a fuel pump boss, which are most late model crate engines. Actually there are more. But these are the high horsepower engines and all use a stock pump with 3/8 fuel lines.
Old Jan 24, 2005 | 11:03 PM
comp's Avatar
comp
cooler fuel to the carb. is a plus there is some HP loss with a mech. pump (not much i know)
Old Jan 24, 2005 | 11:05 PM
comp's Avatar
comp
Old Jan 25, 2005 | 04:09 AM
Turbo-Jet's Avatar
Turbo-Jet
As a theft deterrent, you can easily install a secret switch to disconnect power to an electric pump. peace of mind is worth something too
Old Jan 25, 2005 | 06:43 PM
comp's Avatar
comp
true a small plus
Old Jan 25, 2005 | 06:57 PM
Mike Ward's Avatar
Mike Ward
This advantage is more than completely offset by the extra load put on the alternator which must produce the electricity to run the pump. No free lunch here.
Old Jan 25, 2005 | 07:04 PM
isosceles's Avatar
isosceles
My Holley Blue only draws 3 amps. That can't produce much drag. But neither can moving a pushrod .375". I agree, must be a wash.
If I took the time to verify I hadn't damaged that end of the cam with a bent fuel pump pushrod, I might not have recently switched. I liked the idea of consistant fuel pressure.
The installation of the electric pump was a little time consuming though.
Old Jan 25, 2005 | 07:45 PM
Marks69BB's Avatar
Marks69BB
I think my electric helps on startups since as soon as you turn the key, you have fuel pressure. My BB vette starts almost instantly like a modern car with FI.
Old Jan 25, 2005 | 07:57 PM
Twin_Turbo's Avatar
Twin_Turbo
and if you wire your fuel pum w/ an oil pressure cut off switch it could save your engine also in case something goes wrong.
Old Jan 25, 2005 | 07:58 PM
oregonsharkman's Avatar
oregonsharkman
edelbrock aluminum mechanical pump----------383 stroker/440hp----runs perfect!!!!
Old Jan 26, 2005 | 10:29 PM
68/70Vette's Avatar
68/70Vette
I don't know for sure, but I've always been suspicious about how good mechanical pumps work at high engine rpm. At 5000 rpm, the mechanical pump piston is working at 2500 pulses per minute. That's 41 pump pulses per second! I just wonder if the fuel starts to cavitate. With my mechanical pumps, I think I've experienced high rpm power drops at high power (full throttle in fourth gear). Just to get rid of this possible fuel starvation problem, I've decided to install an electric pump.
To Mechanical Vs. Electric Fuel Pumps
Old Jan 26, 2005 | 11:07 PM
greyghost79's Avatar
greyghost79
if mechanicals are so good (and i'm very happy with mine), why are they putting electrics on just about all cars built today?
Old Jan 26, 2005 | 11:32 PM
68/70Vette's Avatar
68/70Vette
All the engines today are fuel injected and they need high fuel pressures for the injectors. I think this is why they use all electric today. The electric fuel pumps for today's engines produce much more pressure than the electric pumps designed for carbs. (This is my belief based upon reading fuel pump vendor descriptions.)
Old Jan 26, 2005 | 11:48 PM
GDaina's Avatar
GDaina
About 40lbs
