Turn Signal Short
Old Jan 24, 2005 | 05:59 PM
MPSJM's Avatar
MPSJM
Default Turn Signal Short
We just started having an intermittent short in the turn signal. We replace the fuse and it will work for a while then the fuse will blow. Any ideas where to start looking and how to trace this? The emergency flasher still work after the fuse blows.
Old Jan 25, 2005 | 11:54 AM
Marv's Avatar
Marv
First place I look is at all four bulbs and inspect very closely for a filament sagging onto another. If your side markers also blink then check them as well. Then make sure the sockets are clean with good contact. Does the fuse blow at right or left turns? That might narrow it down. Good luck.
Old Jan 25, 2005 | 12:11 PM
MPSJM's Avatar
MPSJM
Found the problem it was not the turn signal but the backup light which runs on the same circuit. The wire down at the switch on the transmission had shorted against the sheild protecting it. So it would only short when I went into reverse
Old Jan 25, 2005 | 12:25 PM
81' Corvette Guy's Avatar
81' Corvette Guy
Nice find..way to go bro!
To Turn Signal Short
