another torque specs question:
Old Jan 25, 2005 | 12:03 PM
GrandSportC3's Avatar
GrandSportC3
Cruise-In IV-V-VI-VII-VIII Veteran
St. Jude Donor '03, '06, '17
Default another torque specs question:
How much torque on the bolts that connect the transmission mount to the transmission?
How much torque on the bolts that connect the transmission mount to the crossmember?
Thanks in advance
Old Jan 25, 2005 | 12:18 PM
GDaina's Avatar
GDaina
is that a 3/8 bolt? if yes no more than 25 lbs
The 7/16" around 35-40 lbs....I think both are grade 5
Old Jan 25, 2005 | 12:49 PM
GDaina's Avatar
GDaina
Oliver you need to go to a nut and bolt place and pick up a bolt chart...
the chart will give you torq specs for every bolt size and grade, including metric..
Old Jan 25, 2005 | 12:54 PM
superdad60's Avatar
superdad60
How about tie rod ends?
Anyone have the magic number?
I need a chart too
Old Jan 25, 2005 | 12:55 PM
superdad60's Avatar
superdad60
How about tie rod ends...
Anyone have that magic number?
I need that chart too I guess
Old Jan 25, 2005 | 03:22 PM
redc3's Avatar
redc3
i have the chilton manual and its giving me everything BUT that info, sorry.
Old Jan 25, 2005 | 06:44 PM
StickShiftCorvette's Avatar
StickShiftCorvette
These numbers should be gotten from the specs in the Chevrolet Chassis Service and/or Overhaul manuals. You should NOT use standard torques, since some bolts go into aluminum and MOST bolts (even when threaded in cast or steel) are specified to torques DIFFERENT than the "standard" values.
Old Jan 25, 2005 | 06:47 PM
Jim Shea's Avatar
Jim Shea
Tie rod ends are: 35 ft-lbs plus additional torque required to align castellation with the cotter pin hole in the stud (not to exceed 50 ft-lb max).
Old Jan 25, 2005 | 06:50 PM
jimvette74's Avatar
jimvette74
Thanks in advance
factory spec is 35 to 45 ft lbs
Old Jan 26, 2005 | 12:21 AM
GrandSportC3
thanks!!
I won't be able to use the torque wrench on the bolts that connect the transmission mount to the transmission.. but the specs will give me some kind of idea on how tight I'll have to tighten them!!
Old Jan 26, 2005 | 06:08 PM
superdad60's Avatar
superdad60
Thanks Jim
To another torque specs question:
