jack location
Old Jan 28, 2005 | 01:34 PM
groran's Avatar
groran
Default jack location
Where is the jack on 95 c4? The car has been re carpeted.GM dealer says side panel on the side???????I dont see anything there, any help appreciated
Old Jan 28, 2005 | 01:36 PM
89sleeper's Avatar
89sleeper
From: The land of 10,000 lakes ,Minnesota 89 coupe 6speed with 383 and 89 roadster 6speed bonestock with XXX low miles
Not sure about the 95
On my 89 the jack is on top of the spare tire in the rear!
Old Jan 28, 2005 | 01:48 PM
dcandel's Avatar
dcandel
Oldtimer
Default Jack location
Open the trap door behind the passenger seat. Lift out the tray. The jack should be underneath the tray.
Old Jan 28, 2005 | 01:49 PM
ZRWON's Avatar
ZRWON
THERE SHOULD BE A PANEL BEHIND THE PASSENGER SEAT WITH A DOOR HANDLE TO LIFT. INSIDE I THINK THERE'S A PLASTIC BIN THAT LIFTS OUT BUT I DON'T THINK THE JACK WAS STORED UNDER THAT BIN...CAN'T REMEMBER FOR SURE.
(Sorry about "Caps lock being on") I only owned one of the newer years you mentioned...'96.
All the other C4s we owned were '93 and older and I think those all had the jack stored above the spare tire. Good luck with your search and enjoy your "Vette way of life".
Old Jan 28, 2005 | 03:02 PM
avideo's Avatar
avideo
Default I Own A 1995 Coupe...
and your jack should be in the bottom of the storage compartment behind the pasenger seat. If it's never been used, there is probably a tag on it too.
Old Jan 28, 2005 | 03:08 PM
tm1995c4-LT1's Avatar
tm1995c4-LT1
You should also have a locking lug adapter in there too. Your lug wrench (in case you haven't found it yet) should down on the floor behind the driver seat.
Old Jan 28, 2005 | 04:12 PM
John Robinson's Avatar
John Robinson
Default 93 Coupe
Mines on top of the spare tire
Old Jan 28, 2005 | 04:13 PM
myvettesblue's Avatar
myvettesblue
St. Jude Donor '05
in 1994 they relocated the jack from the top of the spare tire to the compartment behind the passenger seat. thanks to the corvette black book
Old Jan 28, 2005 | 04:28 PM
WildBill95's Avatar
WildBill95
The jack should be in a styrofoam holder under tray behind drivers seat . It was moved from the spare tire when a spare tire delete option was made available ( I believe ) . If the foam jack holder is missing you will see the radio cdm box ( basically the part that recieves the radio signal ). It should also have your wheel lock socket with the jack . If its gone you may want to address this before you have a flat tire . Hope this helps.....
Old Jan 28, 2005 | 07:45 PM
redwing76's Avatar
redwing76
C-4's have a spare?
Old Jan 28, 2005 | 07:46 PM
myvettesblue
St. Jude Donor '05
Originally Posted by WildBill95
The jack should be in a styrofoam holder under tray behind drivers seat . :
actually behind the passenger seat
Old Jan 28, 2005 | 11:07 PM
VQT88Vette's Avatar
VQT88Vette
Originally Posted by redwing76
C-4's have a spare?
Yes, same diameter but as thin as it can be, 70 psi, store under the gas tank. Most of the time when you needed it the thing was out of air tkaes too much time to check the air pressure of the spare
Old Jan 28, 2005 | 11:44 PM
kenv's Avatar
kenv
From: levittown pa. usa Even a bad day with my `Vette, is better than a good day at work
St. Jude Donor '10
You can pick up a reproduction owners manual from places like MAD, for around $20, for your year car. Its a good thing to have, as it tells you where everything you need to get to, ( like the jack, fuses, etc. is ). Then your next step is to get a factory service manual, so you can really start to have fun.
To jack location
