trans removal tips?
Old Feb 1, 2005 | 07:43 PM
c4sforever's Avatar
c4sforever
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '06
Default trans removal tips?
i will be pulling my tranny out soon to fix the overdrive and was wondering if anyone might know of a trick or two to make things easier to get it out of my car.i have an 84 with the 4+3.
Old Feb 1, 2005 | 08:16 PM
bogus's Avatar
bogus
It's rather easy... just lotsa bolts.
You will want a tranny jack to help support the weight.
Do you have the Helms Manual? www.helminc.com - They provide the factory service manuals for GM. It is all but required.
Old Feb 1, 2005 | 08:27 PM
BRICHC4's Avatar
BRICHC4
good idea to put it in third gear, will give you a lot more room when removing and installing the transmission
Old Feb 1, 2005 | 08:43 PM
redwing76's Avatar
redwing76
Use 4 ramps.
Old Feb 1, 2005 | 09:03 PM
c4sforever's Avatar
c4sforever
St. Jude Donor '06
Originally Posted by redwing76
Use 4 ramps.
the last time i put a car on ramps to pull a tranny the car came rolling down on me.that car was a 77 nova with about a mile of ground clearance.think i'll use jack stands instead.
Old Feb 2, 2005 | 11:16 AM
fsr402's Avatar
fsr402
St. Jude Donor '06
If you are doing it on jack stands, get yourself one of these. Tranny Jack You'll be glad you did.
Old Feb 2, 2005 | 05:19 PM
redwing76's Avatar
redwing76
You didn't use 4 ramps. The front two face rearward and the back two face frontward the car can't roll anyway.
The object is to get the car as high as possible without a danger of it falling on you.
When you used 2 ramps on the front you didn't block the rear wheels and set the hand brake.
Old Feb 2, 2005 | 05:39 PM
C4Crazy787's Avatar
C4Crazy787
Mine in action, http://forums.corvetteforum.com/phot...ndjack-med.JPG
Old Feb 2, 2005 | 07:29 PM
c4sforever's Avatar
c4sforever
St. Jude Donor '06
Originally Posted by C4Crazy787
funny thing is i have one that looks just like yours.and it will be getting used.
Old Feb 2, 2005 | 07:39 PM
88421VETTE's Avatar
88421VETTE
same here I was crushed by my 88 last summer. Ramps should be outlawed
Old Feb 3, 2005 | 07:35 PM
BRICHC4's Avatar
BRICHC4
I used the parking brake and put it on cinder blocks, that gave me enough clearance and I felt safe
Old Feb 3, 2005 | 07:40 PM
c4sforever's Avatar
c4sforever
St. Jude Donor '06
guess i should refine my question.i was hoping someone new of any safe shortcuts i might use to cut my down time some?i.e. not completely taking out the c-beam,leaving the back half of the exhaust things like that.thanks for any help.
To trans removal tips?
