E brake not connected- rear brake issues?
Old Feb 2, 2005 | 10:45 PM
qwiketz's Avatar
qwiketz
Default E brake not connected- rear brake issues?
I know that the ebrake is not connected on my car. I know that for the rear calipers to work properly, you have to use the ebrake all the time.
Will it be a problem to send it to the shop and have them reconnect it or will everything have to be redone?
Old Feb 2, 2005 | 10:53 PM
Bilyk's Avatar
Bilyk
On the C4, the e-brake operates a seperate set of tiny brake shoes that act on the inside of the rear rotor *hats*
The e-brake does NOT act on the calipers
Old Feb 2, 2005 | 11:13 PM
tonymax2's Avatar
tonymax2
Au contraire--the E brake on the '88 and (I presume) up actuates the caliper pads using a mechanism identical in operation to the little "hold open" slider on a common tubular type screen door closer. It's a bit bigger and more rugged, of course.
Old Feb 2, 2005 | 11:20 PM
qwiketz's Avatar
qwiketz
well, that's good to know. I read in 101 corvette projects that it was imperative to use your ebrake each time the car was parked.
Old Feb 2, 2005 | 11:21 PM
tonymax2's Avatar
tonymax2
[QUOTE=qwiketz]I know that the ebrake is not connected on my car. I know that for the rear calipers to work properly, you have to use the ebrake all the time. ........QUOTE]
I don't understand "all the time"....what do you mean? I think your '92 has the same "2nd generation" E brake that started in '88 and I don't see any reason why it being connected or unconnected would make any difference in the operation of the caliper function.
Old Feb 3, 2005 | 02:09 AM
JCAIRE2's Avatar
JCAIRE2
The rear calipers on '88 and up are not self adjusting. They are adjusted through the action of the ebrake mechanism.
Old Feb 3, 2005 | 02:10 AM
qwiketz's Avatar
qwiketz
so with that being said, will the shop have to do anything special to get my brake system back in order or will they just have to connect the ebrake?
Old Feb 3, 2005 | 02:39 AM
JCAIRE2's Avatar
JCAIRE2
Can't say, I'd have it hooked back up and see if it works. Do your rear brakes work at all currently? Is there rust on the area of the rotors that is swept by the pad?
Old Feb 3, 2005 | 02:44 AM
myvettesblue's Avatar
myvettesblue
St. Jude Donor '05
sounds technical
Old Feb 3, 2005 | 04:18 AM
Jeffvette's Avatar
Jeffvette
From: No more yankee my wankee, the Donger is tired!
Originally Posted by myvettesblue
sounds technical
Old Feb 3, 2005 | 06:57 AM
super89's Avatar
super89
Just make sure that after you disable the automatic tensioner with a pin (not a screw), that you remove it after everything is all hooked up. Whoever previously worked on my e-brake used a screw, which broke off and disabled my e-brake until I figured out what was wrong and drilled it out.
Old Feb 3, 2005 | 01:34 PM
qwiketz's Avatar
qwiketz
the rears work slightly. The surface rust gets taken off each time I drive it.
Old Feb 3, 2005 | 07:24 PM
JCAIRE2's Avatar
JCAIRE2
Have you tried adjusting the ebrake yet? since the rear brakes do remove the surface rust, I'd say that they are just a little out of adjustment. Just engage and disengage the ebrake a whole bunch of times. couldn't hurt to try?
Old Feb 3, 2005 | 10:41 PM
qwiketz's Avatar
qwiketz
I"m not sure what's going on because it doesn't even feel like the ebrake is connected when I pull the handle.
To E brake not connected- rear brake issues?
