Spark Plug Wires
Old Feb 4, 2005 | 09:24 AM
LT1SPUD's Avatar
LT1SPUD
Default Spark Plug Wires
..want to replace my wires with some with color...who makes good aftermarket wires? also, i've heard it's worth the money to let a shop with a lift do the replacement....true? thanx.
Old Feb 4, 2005 | 09:39 AM
VR'92's Avatar
VR'92
From: I'm the walkin dude I can see all of the world...
St. Jude Donor '03
Msd
Old Feb 4, 2005 | 09:56 AM
bizaro's Avatar
bizaro
St. Jude Donor '04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14
Just replacing the wires is not so bad. If you are replacing the spark plugs as well, then we are talking serious pain in the a**
good luck
Old Feb 4, 2005 | 10:12 AM
corvetteronw's Avatar
corvetteronw
Cruise-In VII Veteran
Cruise-In VIII
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16
I have used Taylor wires and like them. If you are fairly mechanicaly competent (i.e. can find your butt with both hands) you should be able to do this. Either replace one at a time or label them so you get the new ones connected to the correct plugs. Otherwise it will run like an old Model T. Try www.summitracing.com and use their on line catalog or order own catalog (great for extended bathroom reads).
Old Feb 4, 2005 | 11:26 AM
glerma's Avatar
glerma
St. Jude Donor '05
LOL... I here ya brother!
Old Feb 4, 2005 | 12:51 PM
96 Collector Edition's Avatar
Default z
I have used Taylor wires and like them. :
Old Feb 4, 2005 | 01:00 PM
SilverBeast's Avatar
SilverBeast
St. Jude Donor '05
I put the red Taylor wires on my '96 LT1, but someone else will do it next time. You have to get under the car to do some of them. And you don't just push these wires on - they have to be seated properly in the distributor. You can feel the "snap" when they are seated. Passenger side is just normal PITA, but driver side is MAJOR PITA.
Old Feb 4, 2005 | 01:01 PM
Jet-Jock's Avatar
Jet-Jock
I went with Taylor Spiro Pro's as well. No complaints here.
To do the plug wires you'll need to remove the belt and belt tensioner. Then you'll have access to both sides of the optispark. The GM Service Manual is very helpful in that it gives excellent drawings of the proper wire routing. That part is a mind bender. The existing wire trees will hold the Taylor 8mm wires any larger and you need new larger size trees.
Fitting the coil wire to the opti is a bit tricky, I found an 11-inch pair of needle nose pliers helps to seat it. Other than that, take your time. Hey your in there might consider the plugs too. I went with NGK Iridiums.
Edit: I don't agree with the notion you have to get under the car. The driver's side is only difficult to the point of routing the wires so the lay in there correctly. If you have the center and rear section of the wheel liner removed you have easy access to that side. Passenger side is straight forward. I believe it is a double click when they seat to the opti.
Old Feb 4, 2005 | 03:18 PM
SilverBeast
St. Jude Donor '05
The '96 has one piece wheel liner.
Old Feb 4, 2005 | 03:33 PM
Yellow95's Avatar
Yellow95
I think your '96 is very close to my '95 6-speed.
The best investment is a six pack for a buddy who has done it before. I didn't consider the plugs on my '95 to be that bad. I think I guessed right most of the time. It still took quire a while. The wires were a PITA. They normally change color from the blood sweat and tears that get spilt on them. The key for me was the belt tensioner (as its states above). The other key is to loosen the power steering pump so you can move it about 1/2 forward to slide the wires in and out. Most of the time I spent on the project was spent just staring at it. Took about 8 hours the first time for the wires with most of the time spent staring at it. The second time I did the wires it was a one hour job. (that's why you need the friend who did it before)
Also, for me, almost all the wire looms broke when I worked the wires in and out of them.
Entire job is done from the top.
Old Feb 4, 2005 | 03:38 PM
myvettesblue's Avatar
myvettesblue
St. Jude Donor '05
Originally Posted by VictorRussell'92
Msd
the wires and the plugs are a pita. i found on the drivers side which i thought was the worst side for both was easier to take the center section of wheelhousing out and unbolt the asr and move it out of the way awhole lot less to hassle with
Old Feb 4, 2005 | 05:58 PM
Jet-Jock's Avatar
Jet-Jock
Does it not come out?
Old Feb 4, 2005 | 06:17 PM
SilverBeast
St. Jude Donor '05
Yep, it'll come out, but there's LOTS of stuff bolted to it. I like yellow95s idea. Just plan on spending a lot of time, a bag of 4-letter words, a 12 pack of beer, half a dozen band-aids, and LOTS of patience. It's a PITA, but doable. About the comments about getting under it - I did, but probably could have avoided it by following what yellow95 said. Please let us know how it went after you are done.
Old Feb 4, 2005 | 06:53 PM
Jet-Jock's Avatar
Jet-Jock
Yeah I didn't let on about those items, I figure everyone has to learn that part by themselves.
The part about sitting and staring at it for a quite a while is likewise true, which one goes where and on top of who...
Old Feb 4, 2005 | 08:10 PM
Chris_G's Avatar
Chris_G
St. Jude Donor '05-'06-'07
I had plugs and wires installed by a dealer for $427. That did not include parts. So, you decide if you want to spend the time to do it yourself.BTW, I used Taylor wires.
Old Feb 4, 2005 | 10:21 PM
SilverBeast
St. Jude Donor '05
BTW LT1SPUD, if you decide to go ahead, I highly recommend you do the driver's side first. The passenger side will seem a whole lot easier, and you'll be attacking the most difficult part while you're fresh. Good luck whatever you decide.
Old Feb 5, 2005 | 08:52 PM
proemtpff's Avatar
proemtpff
Just put MSD's on my '86 and I love them. I also put in a Hypertech coil set "cap, rotor and coil" and AC Delco rapidfire plugs......woke the car up some.
To Spark Plug Wires
