replace air pump with idlier
Old Feb 4, 2005 | 01:55 PM
colemanron's Avatar
colemanron
Default replace air pump with idlier
got my motor setting in floor, thanks for help. ? can i use the idler they sell for 85's to replace my smog pump on my 84. don't need all that stuff.
Old Feb 4, 2005 | 09:49 PM
jefft84's Avatar
jefft84
No because the 84 has the P/S tank and bracket above the alternator that the 85 up dont have. I just eliminated my air pump by building a H shaped bracket that goes in its place and still uses the OE belt. Others have removed the pump and used a shorter belt but you still need to support the PS tank bracket where it usually bolts to the Air Pump. If you are not in a big hurry I could duplicate mine and send you one I think it cost me about 35.00 to make.
Old Feb 7, 2005 | 06:02 PM
e-hodges's Avatar
e-hodges
St. Jude Donor '06-'09
Default you can gut the old pump
I have a pump on my 87 that my buddy gutted, just a bearing and pully now. No drag, but if you want to remove the unsightly thing I would find the one that uses the same size pulley, Ive heard of problems with belt alignment on small pulley replacements.
To replace air pump with idlier
