C4 Value?
Old Feb 5, 2005 | 03:58 PM
jasenr's Avatar
jasenr
Default C4 Value?
Hello, I am considering selling my 1991 Corvette. What is a fair price for one in the following condition?
135,000 miles
Needs paint and some fiberglass work where the antenna was.
Interior is good except the drivers seat needs to be recovered and a few other minor things.
Has both tops but the glass one has a small chip that doens't affect water tightness and the "splinters" in the plexi.
Powertrain needs work. The guy before me had tried to do some engine mods with no plan. Thus it does not run strong. It does run ok, just seems weak. Leaks oil around the valve covers. He had also put on aftermarket valve covers. I think it may also have a small trans fluid leak at the pan, but I can't get under there to look.
It has siamesed runners, SVO injectors, bigger throttle body, wide mouth air intake, airpump and egr removed, 3.73 gears, exhaust cut outs, etc...
The tires are good and it has aftermarket wheels. I think they are called a-molds???
The electronic climate control is not directing airflow properly.
Bose CD audio seems to be in good working order as are the electric seats and air bladders. (I think. I have never had a Vette before this one)
Anyway, I have some pics but am not sure how to post them.
I am not sure what I should expect to be able to get. I am just trying to decide if I should sell or restore. I really don't have the time or funds to work on the car much so it is just sitting. Any thoughts are appreciated!
Old Feb 5, 2005 | 04:53 PM
Zproud's Avatar
Zproud
Well you asked
91 vette 135k driver ,value 5 to 7 grand
your car needs work . paint , motor work . seats repaired. with out seeing it first hand 3 to 5 grand +or -
Old Feb 5, 2005 | 05:00 PM
kwik_ta's Avatar
kwik_ta
From: St. Peters MO Sometimes you have to prove yourself by doing alot of killing or alot of dying...
Um... I'd only give $2500 for it as described and that may be generous.
Old Feb 5, 2005 | 05:13 PM
*89x2*'s Avatar
*89x2*
From: ...tearing up the highways, one state at a time™®©
Default youasked...
4 grand if it runs smooth - onlycause I could part it out for more...
Old Feb 5, 2005 | 05:39 PM
White Six Speed's Avatar
White Six Speed
Maybee $3.000 to use as a parts car
Old Feb 5, 2005 | 05:45 PM
White Six Speed
Go to the thread Corvette Price Calculator and I am sure you will like the quote, I sure did on mine!
Old Feb 5, 2005 | 06:02 PM
redwing76's Avatar
redwing76
Check the local adds.
Price accordingly.
Old Feb 5, 2005 | 06:43 PM
vnepilot's Avatar
vnepilot
St. Jude Donor '06
ive been looking on ebay pretty regularly in the past 3 months for a decent daily driver. from what you described, corvettes in that range have been going fo between 4,500 and 7,500... good luck
Old Feb 8, 2005 | 10:38 AM
jasenr's Avatar
jasenr
Here are some pics of the car.
Old Feb 8, 2005 | 02:04 PM
snoopdan's Avatar
snoopdan
Yikes, looks the the antenna blew up! or got caught by a car wash.
Id guss if you were to sell it for 3500 you'd be giving some poor first corvette owner a break. Id consider buying it if it was close to me.
snoopdan
Old Feb 8, 2005 | 06:19 PM
jasenr's Avatar
jasenr
Actually, the guy that owned it before me had a girlfriend back into it...
To C4 Value?
