Engine Starts weird !!!
Old Feb 5, 2005 | 08:39 PM
jay007's Avatar
jay007
Default Engine Starts weird !!!
my 92 starts right up when cold and runs great but when started while the engine is hot it cranks and cranks for about 6 seconds before it starts. and when it finally starts i hear what appears to be detonation for a few seconds and then runs normal. any ideas... ?
Old Feb 5, 2005 | 10:31 PM
8388's Avatar
8388
St. Jude Donor '14
Take a fuel pressure reading after the fuel rail has been purged. If you lose fuel pressure immediately, you probably have leaky injectors. Fuel saturated spark plugs don't ignite very well. If the leak is big enough, you run the risk of washing a cylinder. No bueno.
P.S. if it's not fuel injector related, then I would start checking your ignition system/timing.
Old Feb 5, 2005 | 11:04 PM
bogus's Avatar
bogus
timing isn't setable on an LT1.
Old Feb 5, 2005 | 11:29 PM
8388's Avatar
8388
St. Jude Donor '14
I know. But it could be screwed up, due to a bad ignition sensor.
Old Feb 6, 2005 | 12:15 PM
redwing76's Avatar
redwing76
Try a pedal down start to test the injectors.
To Engine Starts weird !!!
