SYS light
Old Feb 6, 2005 | 08:06 AM
yboy03's Avatar
yboy03
7th Gear
Default SYS light
Well decent day here in Ohio yesturday so I thought I would get out the vette. Drove around for a couple hours, stopped in at he video store rented a video (Papparazzi). Hop in the car, starts fine now sys light is flashing,the radio does'nt work and heater controls don't work. Any ideas please help. 92 coupe
Old Feb 6, 2005 | 09:38 AM
VFR750's Avatar
VFR750
Typically a flashing SYS means your battery is going south, but it can indicate many more things than that, and since you have other symptoms, I'm guessing it's not (just) your battery.
There have been threads about this in the past, some including very detailed procedures and code keys, but since searching is disabled for some reason, I can't locate them. Maybe these helpful posters will chime in again. Good luck.
Old Feb 6, 2005 | 10:02 AM
rlt96vette's Avatar
rlt96vette
i would try a new battery first or remove it and take it to auto zone and have them check it if it is week it could cause those things to not work i had the sys flashing to but everything worked but leraned from the good members here it was the battery......
To SYS light
