Engine washing
Old Feb 6, 2005 | 01:06 PM
Sprout's Avatar
Sprout
Default 1986 Engine washing
Has anyone ever power washed there engine? and what do you use and how well does it work. My engine is pretty clean but would like it cleaner.
Old Feb 6, 2005 | 01:49 PM
Hogan's Avatar
Hogan
From: First to Sign Grumpy's Hat Only 53 miles from Hell
St. Jude Donor '06-'09-'10-'11
What year is your Vette??? Power washing earlier LT1 cars is not a good idea because of the opti. If your engine compartment is already pretty clean then I would just use an old wash mit and soap and water and get into the nooks and crannies. Then wash down with the hose using a fine mist.
Old Feb 6, 2005 | 02:14 PM
drvn2fast's Avatar
drvn2fast
how about washing the l98??? :o
Old Feb 6, 2005 | 02:42 PM
Chris_G's Avatar
Chris_G
St. Jude Donor '05-'06-'07
If you have the LT-1 (opti spark) be very careful.
Old Feb 6, 2005 | 02:51 PM
NightFlight's Avatar
NightFlight
Shouldn't hurt it. But heres another method that seems to work for me. Spray down the engine compatment with Simple Green, especially soaking the really bad areas and avoiding potential danger areas (alternator and electrical connectors). Let sit for a few minutes and wipe/wash with an old wash cloth or rag also soaked in Simple Green. Rinse with a garden hose. Takes a little time, but I think its a little safer then a power was and you get good results ....
Old Feb 6, 2005 | 03:13 PM
lbitp37's Avatar
lbitp37
I used to use Simple Green, but switched to Orange Blast, I found it to be Much Better.
After spraying it on use a paint brush to work on the real grime.
Old Feb 6, 2005 | 04:43 PM
C4Crazy787's Avatar
C4Crazy787
Use hot water, that helps to.
Old Feb 6, 2005 | 05:20 PM
SilverBeast's Avatar
SilverBeast
St. Jude Donor '05
Yep, I pressure washed my '96 CE when I first got it. Cost me $900 for opti, distributor and Crankshaft position sensor. Wish I had known this forum existed before I did that...
Old Feb 6, 2005 | 06:36 PM
85 500 horse's Avatar
85 500 horse
I powerwashed my L98 for about 10 minutes straight. And I kept the water's pressure up pretty high. I just tried to keep the spray away from the backside of the engine (where the distributor is).
Then I sprayed all the greasy areas with a concentrated degreaser. I waited about 5 minutes and pressured washed it again. Then the areas that were grease stubborn, I hand cleaned. It took some elbow grease for those spots. Then I washed it down again with the pressure washer.
I kept the car in the sun (with the hood still up) for a few hours to let everything dry. I applied dielectric grease on the windshield wiper's relay's contacts in case any water seeped in.
I started her up with no problems. I'm not advocating doing this. I'm just saying I didn't have a problem when I did it.
Old Feb 6, 2005 | 11:54 PM
flylowguy's Avatar
flylowguy
Default I pressure washed my '85 with no adverse consequences
I used commercial degreaser, then hot soapy pressure, then low pressure cold rinse. It comes out real real clean. I covered the distributor and put some plastic on a few relays and electrical connectors. I hit the suspension and underside as best I could reach. Right after, it started up no problem. Later I sprayed the whole underhood with tire foam and then wiped it all down. It looks new.
Maybe you could cause problem doing it the way I just described if you are not careful, though. It might be best to let it cool down before you begin.
Old Feb 7, 2005 | 01:54 AM
RIISITAS's Avatar
RIISITAS
I use Simple Green too. Looks like I'll have to try the Orange Blast. Thanks for the tip.
Old Feb 7, 2005 | 01:59 AM
vader86's Avatar
vader86
If its an L98, have at it. Try not to get the distributor or the MAF soaked. Don't start it up immediately if you do hose down the TB and MAF, let it dry for a minute.
Old Feb 7, 2005 | 07:11 AM
raw122's Avatar
raw122
i just spray on degreaser let it soak in and then take my pressure washer to it ,now that i have my delteq kit i do it about once every month or to,since i did he degreaser the 1st time now i just take the washer to it
Old Feb 7, 2005 | 07:19 AM
Aquaman92's Avatar
Aquaman92
Default Castrol Degreaser
I use Castrol they make a great spray degreaser
Old Feb 7, 2005 | 09:11 AM
cicch95's Avatar
cicch95
Finalist 2020 C4 of the Year - Unmodified
Power washing ANY LT1 is not a good idea! Vented or not....water is the ENEMY of the opti!
-Rick
Old Feb 7, 2005 | 10:17 AM
ZumZum's Avatar
ZumZum
I've been using Orange Blast on suspension components and everything else that gets grease, oil or grime buildup on it.
Orange Blast
Formula 409
Wire brush
Lots of rags
Works good for me.
To Engine washing
