Hood release cable broken
Old Feb 7, 2005 | 11:11 AM
BOGY 7's Avatar
BOGY 7
2nd Gear
Default Hood release cable broken
Went to stary my 89 in storage pulled the hood release to connect the battery and only the drivers side released believe its a cable problem any tricks on getting the hood open.
Old Feb 7, 2005 | 11:44 AM
Kwikerthanu's Avatar
Kwikerthanu
St. Jude Donor '05-'06
I went through that on my '92. I thought the cable was broken, so I got my wife to lift on the corner of the hood that didn't come up as I pulled the hood latch. It finally released after a couple of tries. The cable wasn't broke, but was out of adjustment. Made the minor adjustments and everything works as it should.
Might try that, your helper doesn't have to pull up very hard. Just use a steady upward pressure.
Old Feb 7, 2005 | 11:48 AM
rick lambert's Avatar
rick lambert
Some of the vendors sell a tool for it-Vinnies87 has a document on how to make the tool-he sent it to be, but for some reason I couldn't open the file.
Old Feb 7, 2005 | 03:10 PM
purplemajesty's Avatar
purplemajesty
If my memory serves me right, in the space between the winshield and hood, there is an access hole about 1/2" in diameter on the left side of where the latch would be. You will have to stick at least a 6" screwdriver through there and feel around for where the cable attached to the latch. When you find it, pry it so that you pull the handle of the screwdriver towards the passenger side of the car. It won't take a lot of force but it won't be real easy either. It will take some patience, but at least you won't have to wait to get the tool.
Old Feb 7, 2005 | 03:21 PM
Wayne88's Avatar
Wayne88
If all else fails, do what I did:
I took the wheel and wheel well off, reached up with a chisel and pushed the latch open.
I have that 'tool', but I just don't have the ability to make it work
Old Feb 7, 2005 | 06:24 PM
JCAIRE2's Avatar
JCAIRE2
Take the surround off for the handle and you'll see the cables, see if you can open it by grabbing the cable on the right. If the cable is not broken that should get your hood open. Had to do that today myself.
Old Feb 7, 2005 | 11:14 PM
vinnies87's Avatar
vinnies87
St. Jude '03-'04-'05-'06-'07
Rick: Send me an email and i'll resend them in std format for you... been a while, hope all is good with you... vdaddio@comcast.net
vinnie
To Hood release cable broken
