brake dust shields
Old Feb 8, 2005 | 11:12 AM
LT1SPUD's Avatar
LT1SPUD
Default brake dust shields
...i'm getting alot of brake dust build up on my left front wheel...thinking of installing brake dust shields....anybody else installed them? how well do they work?
Old Feb 8, 2005 | 11:27 AM
c4cruiser's Avatar
c4cruiser
Your'e still going to get some dust build-up. The factory wheels use the "vanes" designed into the wheel to get air to pass thru the wheel and cool the brakes. A shield will restrict the airflow and you may see excessive heat in the brakes which can raise the temperature of the brake fluid to the point where it will boil and result in serious brake fading.
Are you not getting dust on the other wheel?? It sounds like there is either different pad types installed or one brake caliper is not working properly.
Old Feb 8, 2005 | 03:02 PM
Z51JEFF's Avatar
Z51JEFF
Ive got a set id sell for $30.00 including shipping.There Kleen Wheels.They keep some dust off the wheels.
Old Feb 8, 2005 | 03:25 PM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
That and/or a low dust pad will do the trick, but both will decrease your braking potential somewhat.
If you don't race it, it probably won't matter.
Old Feb 8, 2005 | 04:10 PM
mitymek's Avatar
mitymek
brake dust is always a nuisance (it seems),but if its uneven i would be for taking it apart and seeing why.
you may have some scoring on the left rotor or the right brake may not even be working.does it pull under hard braking?
as far as those shields go,find a pic of some installed,you will likely pass on that option.with most wheels they are pretty ugly.(uglier than dust anyway)
dont know about which pads are better for dust,but i have ceramics on mine and they do leave dust on the wheels,plus they are noisy when cold.seem to grab when i need em tho,and thats all i care about in a brake pad.
Old Feb 8, 2005 | 05:56 PM
85vetteguy's Avatar
85vetteguy
They work very well.
Old Feb 8, 2005 | 07:54 PM
Runum's Avatar
Runum
I have seen them used on a Chevy 1/2 ton truck. Over time they kept his wheels cleaner. They also caused his rotors to turn blue, warp, and crack. I will not put them on my car. Personal opinion....
Old Feb 8, 2005 | 08:03 PM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
Have you checked to see if the pads on that side are worn more? It sure sounds like you could have a caliper dragging on that side. An internally collapsing flexible hose can cause the same thing by also causing excessive drag. Fix the problem, get ceramic pads and forget about the shields. Anything that retains brake heat is not a good thing on any kind of car.
Old Feb 8, 2005 | 08:10 PM
kwik_ta's Avatar
kwik_ta
From: St. Peters MO Sometimes you have to prove yourself by doing alot of killing or alot of dying...
It sounds like you have a brake problem that needs to be addressed... and while you are at it... ceramic pads don't leave dust.
To brake dust shields
