No start problem
Old Feb 9, 2005 | 05:31 PM
jabez's Avatar
jabez
Default No start problem
Try to take my 92 out to go to work. Turn key and nothing. No crank at all. Battery is A OK. Lights nice and strong. Everything lite up when i inserted key. Asking here first because I know you guys will know.
Old Feb 9, 2005 | 05:48 PM
ZumZum's Avatar
ZumZum
I don't know if your car has a VATS system like my '88, but it could be a problem with that or something similar. If the VATS gets activate on mine I just don't touch the key for 4-5 minutes, then try. Usually starts right up then.
Old Feb 9, 2005 | 07:58 PM
85 500 horse's Avatar
85 500 horse
Sounds like the VATS. If you have a spare set of keys, try them first. If that doesn't work, check your battery cable connections. Make sure they're all good and tight and not corroded. I doubt it's the starter. They normally give you warning when they're going.
Old Feb 9, 2005 | 08:05 PM
jabez's Avatar
jabez
Thanks guys..it was the key. Tried Spare key and it fired right up. Guess pellet was dirty or worn.
To No start problem
