Headlights?
Old Feb 13, 2005 | 05:23 PM
zr2tim's Avatar
zr2tim
Default Headlights?
I asked this question before, but went out of town for work,
and wasn't able to find it after. Anyway.....
The stock C4 headlight aren't good, and I need opinions on
Hella vs. Silverstar.
Hellas are about $60 ea., where as S/S are around $20 ea.
Anyone used both?
Old Feb 13, 2005 | 05:43 PM
Muffin's Avatar
Muffin
I have gone from stock to plastic kits with replacable bulbs to SS. While improved,I am not overly impressed with any of the so-called brighter lights. Would love to see Hellas. I won't spring for that kind of money for something that is only marginally better than what I have. I didn't answer your question but did share some experiences.
Old Feb 13, 2005 | 05:58 PM
VenkmanP's Avatar
VenkmanP
Hella was one of the first things I did when I got mine. Probably the best investment I've made in the car.
Old Feb 14, 2005 | 11:41 AM
dizwiz24's Avatar
dizwiz24
Hella glass reflectors are good (although heavier than stock).
When you buy bulbs for them, do not get the stupid fake HID blue tint bulbs.
THe blue tint detracts from your low beam performance (usually the high beam filament is not covered by the blue coating).
Old Feb 14, 2005 | 11:44 AM
dizwiz24's Avatar
dizwiz24
Go for e-spec Hella reflectors too, the lighting pattern is better and you wont blind oncoming drivers (at least on your low-beams, turn the high beams on and you might invite some road rage incidents...)
The best setup ever (and i currently have) is daniel sterns setup.
Do an internet search for daniel stern lighting.
He set me up with Bosch e-specs reflectors (better than hellas), Narva 100/130 watt clear bulbs AND a relay kit to install 10 gauge wiring directly off the battery to the headlights.
Old Feb 14, 2005 | 01:20 PM
pletner's Avatar
pletner
[QUOTE=dizwiz24]Go for e-spec Hella reflectors too, the lighting pattern is better and you wont blind oncoming drivers (at least on your low-beams, turn the high beams on and you might invite some road rage incidents...)
When I was growing up my dad installed aircraft landing lights for his high beams on his 73! Man you could literally see for miles on a deserted hwy. I think he was in danger of igniting the grass on the side of the road!
Old Feb 14, 2005 | 05:50 PM
John Robinson's Avatar
John Robinson
Default Lights
I also have a 93. I took the wagner's out and put Hella's in and used the bulb they provided.
The light pattern is much better
The lights are brighter
Were a snap to put in
I would recommemd going that way with the Hella's and bulbs before you spend a lot of money on 80/100 etc. I found the improvement was more than acceptable and am glad I tryed this set up before I went off on a wild tanget spending even more money
Old Feb 14, 2005 | 05:59 PM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
[QUOTE=pletner]
I had those on a car once too years ago. Illegal as hell but they literally lit up the road ahead and even a good distance to the side like daytime. Great for when some butthead wouldn't dim their brights. If I turned them on (if they ignored the normal warning) I guaran-damn-tee you they would dim them then!
Old Feb 14, 2005 | 06:37 PM
NC2Stay's Avatar
NC2Stay
Default Silverstar
I don't drive much at night, but just wanted to be prepared. So I went cheap and bought the Silverstars. Seem pretty good - bright and well focused beam.
But they have a limited life. They estimate 1 year of normal driving. Check that out at their website..
Bob
Old Feb 14, 2005 | 11:26 PM
C4DC's Avatar
C4DC
St. Jude Donor '06
I like my Silverstars. They are much better than the stock ones. I'd say the Hella's are better though, but more $$$
To Headlights?
