correct?
Old Feb 13, 2005 | 11:25 PM
BRICHC4's Avatar
BRICHC4
Default correct?
I've researched and just want to make sure this is correct for wheel sizes on my 95
bolt pattern : 5 x 4.75
offset : 40+
Old Feb 13, 2005 | 11:32 PM
teebee's Avatar
teebee
2021 C6 of the Year Winner - Unmodified
The standard offset for a '95 is 56mm I think. 9.5 in the rear and 8.5 for the front wheels were standard and the Z07's had 9.5 all the way around. 5 lug on 4.75" sounds right though. The earlier 84-87 had 36mm offset if I'm not mistaken.
Old Feb 14, 2005 | 12:42 AM
kwik_ta's Avatar
kwik_ta
From: St. Peters MO Sometimes you have to prove yourself by doing alot of killing or alot of dying...
Um... what he said...
Old Feb 14, 2005 | 01:07 AM
BAM92's Avatar
BAM92
Actually +38 is for the front 17x9.5 and +36.5 for 11 inch rears on the 84-87 and ZR1's. Later ones used +56 for the front and +50 when going to GS 11 inch rears.
Old Feb 14, 2005 | 07:36 PM
BRICHC4's Avatar
BRICHC4
so 56 on the back spacing?
Old Feb 14, 2005 | 08:24 PM
c4cruiser's Avatar
c4cruiser
+56mm is the offset for 1988-1996 C4's except for the 96 Grand Sport with a +0mm rear offset for its 11" wheel. The ZR-1 specific rear wheels were 36.5mm offset. The 84-87 cars used a wheel with a 38m offset.
The backspacing should be 7.4" for all 9.5x17" wheels and 1" less for the C4 8.5" front wheels.
The lug pattern for all wheels is 5x120.65mm. While that's the service manual listed dimension, it should be very close to 4 3/4".
Old Feb 15, 2005 | 09:52 AM
BRICHC4's Avatar
BRICHC4
awsome thanks
Old Feb 15, 2005 | 09:59 AM
rocco16's Avatar
rocco16
From: SCMR Rat Pack'r Charter Member..Great Bend KS
What he said.
Just remember, backspacing is not the same (number) as offset.
Larry
code5coupe
To correct?
