Questions on Spark Plug Wire replacement
Old Feb 15, 2005 | 01:30 PM
alski444's Avatar
alski444
Default Questions on Spark Plug Wire replacement
I am replacing the spark plug wires on my 96 LT-1 vette.The right side went OK,but on the left side the belt tensioner assembly is in the way to get at the Opti-spark, to remove the wires.Is their any precautions I should know about,before talking off the belt tensioner assembly. Like will it recoil or should I mark it somehow.Thanks in advance.
Old Feb 15, 2005 | 01:37 PM
myvettesblue's Avatar
myvettesblue
St. Jude Donor '05
i changed mine without removing anything was'nt easy but it's doable
Old Feb 15, 2005 | 02:23 PM
VenkmanP's Avatar
VenkmanP
Tensioner R/R is straightforward. No hidden gotchas that I can recall. It does make the wires easier.
Old Feb 15, 2005 | 02:45 PM
myvettesblue
St. Jude Donor '05
it probably would, it was a pain in the a$$ with it on, passenger side is a breeze do it last for a calm down session
Old Feb 15, 2005 | 02:46 PM
n1kki6's Avatar
n1kki6
I came up from the bottom, about two hours, 6 beers, and a bunch of bruises and scratches i was done.
Old Feb 15, 2005 | 03:05 PM
Yellow95's Avatar
Yellow95
I took the tensioner off. No tricks involved. It is only held on by one bolt. I took the pully off first. When you put it back on there is a tit that you fit into a indent in the block to make sure it is lined up right.
After doing the wires by removing the tensioner, that is the only way to do it.
Old Feb 15, 2005 | 03:11 PM
SilverBeast's Avatar
SilverBeast
St. Jude Donor '05
Didn't we just go through this?
Old Feb 15, 2005 | 04:29 PM
alski444's Avatar
alski444
Thanks for the info!!!
To Questions on Spark Plug Wire replacement
