Got a used cluster a couple weeks back, everthings works pretty good. It appears that the cluster was from a stick car because it has the upshift arrow and one to four light. Anybody know if I can disconnect the one to four display. I have an auto 84 and don't need the indicator telling me to shift.
I think they all had the upshift light (arrow)and the OD light, mines an 87 auto and it has it, another member with an auto also has it in his. I think they were just for fuel economy savings.Both ours kept comming on-at least until I replaced my fuel pump.Don't know about the 1-4.
I don't know for a fact, but I bet the 1-4 is from an 89. My 87 is also auto and the upshift light does work in it if I'm in 1-3 for any length of time.
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
First off, is the upshift light coming ON? Or are you running in 2nd all the time?
Since you have a spare maybe you can dismantle the assembly and use some black paint and BlackOut the the upshift indicator? I considered doing this to that stupid label about using unleaded gas. Like where can anyone find leaded gas these days. But I figured I was just being **** and choose to simply ignore the message.
There is not a bulb for the upshift indicator. Only the bright lite and turnsignals use bulbs.
I also have an 87 automatic and have the upshift arrow. The bulb near by I think bleeds over and you can see the outline clearly...but its not lit up... I believe it would go on after an extended ride at highway speeds if not shifted into OD...although I could be wrong on that
