Please shoot me......
Old Feb 20, 2005 | 01:53 PM
flannel_man's Avatar
flannel_man
Cruise-In VI Veteran
Default Please shoot me......
I was installing the short throw linkage on my 84' 4+3 and when i torqued down the 4-3 linkage nut it went into gear. Now its in 3rd gear and reverse and the 4-3 shift is jammed. Tried rocking the car and tuggin the links and its not moving should i grab a bigger hammer or drop the trany for this problem?
Old Feb 20, 2005 | 02:05 PM
myvettesblue's Avatar
myvettesblue
St. Jude Donor '05
i done this to a 79 camaro i had one time and ended up having to unhook all the linkage to get them to disengage. i think that helps relieve some of the pressure
Old Feb 20, 2005 | 03:00 PM
Hogan's Avatar
Hogan
From: First to Sign Grumpy's Hat Only 53 miles from Hell
St. Jude Donor '06-'09-'10-'11
Bang!
Old Feb 20, 2005 | 07:16 PM
kwik_ta's Avatar
kwik_ta
From: St. Peters MO Sometimes you have to prove yourself by doing alot of killing or alot of dying...
Originally Posted by WZDADS
Bang!
you just had to go there
Old Feb 20, 2005 | 07:24 PM
JrRifleCoach's Avatar
JrRifleCoach
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
Bang!
What if you just lay down and we go forward & reverse, forward & reverse, forward & reverse, forward & reverse......
Old Feb 20, 2005 | 08:39 PM
Eddie's 84 vette's Avatar
Eddie's 84 vette
He is right And take your time putting back in it can be a big pain in the A$$ good luck
Old Mar 1, 2005 | 10:04 AM
flannel_man
ok i'll try that again
Old Mar 1, 2005 | 11:07 AM
Daffy's Avatar
Daffy
Florida turtle advocate
St. Jude Donor '05-'06
I've used a hammer to fix that on a 4 speed.... Might need the ford(48oz and up)) hammer...Not really on the ford size...Just tap it into neutral with a small(chevy) hammer
Old Mar 6, 2005 | 04:02 PM
flannel_man
hey i got it. Put the rear wheels on jackstands and wiggled the crap out of the linkage and shifter and got it to free up. Ahh, now do I dust off the box of Poly-graphite bushings or work on the interior and radio......
Old Mar 6, 2005 | 07:45 PM
85 500 horse's Avatar
85 500 horse
I see that you live near Kansas. Maybe if you hold onto a small dog, put on a red pair of heeled shoes, click them together, wish real hard and say, "There's no place for that bolt to go so it will fall right out." Say that two or three times and it might work. Well it sort of did that in the movies.
Just trying to give you an easy solution.
To Please shoot me......
