I am having a problem with my brakelamps on a 1996 C4 coupe. The center lamp works fine, but all other brakelamps do not. The taillamps, rh,lh turn signals and four way flasher work fine. I have installed a new brake light switch. All new bulbs and checked the whole rear wiring harness.No change! Can any one help?
Undriveable in Texas
The only piece left is the turn signal switch and the wire between the brake light switch and the turn signal switch. I would bet on the turn signal switch.
I went thru this 2 years ago and it is definitely the turn signal switch. It drove me nuts for a week before I figured it out. Helms manual shows you how to replace. Good luck, Robert
Thanks for the Help! I will go to the turn signal switch. I knew this was the place for answers. Looking forward to that final payment drive next month!!!!!!!!!!!!!!!!!!!!!!!!!!
